Hi all:
From Scene 7.1.1.81 I'm founding error code 220 when trying to run a Project Point Cloud.
After this I reboot the WorkStation and I'm unable to open the project.
Anyone founds this error? caused by what?
It seems that my best option is to re-do the whole project???
Thans in advance!
LLV
Faro error code 220
- Full Name: Lluis Viladrich
- Company Details: Solumetrics
- Country: Catalonia
- Felix_the_Cat
- Full Name: Felix
- Been thanked: 26 times
Re: Faro error code 220
YES
YES
YES
YES
Get rid of the files
Start from scratch
Anything from that project touches your new project and the new project will be poisoned too
And the worst part is you don’t know until you try to make the project point cloud
Has happened twice to me now
If you go into the point cloud creation log files do you see file access errors
I called Faro a bunch but could not get past the script guys who tell you to reboot your pc, no smart guys available
I think it might happen when you process scans in the new interface twice with the “skip fully processed files” unchecked
I think I was trying to process with laser illumination after I did it with plain color to see if the laser illumination would make it look better
It is the only connection I can think of between my two projects but probably has nothing to do with it
As I said the only way I found was to start from the raw files off the sd cards again
I did manage to get the files out of one by creating a cluster at the root, moving everything into it and then exporting as project from the lower level
That one worked ok for a few days then it went south too
It is something in the database I think as the individual scan files open work and behave correctly in a bunch of other programs
So if you delete the project.dat from the top level revision and then open the project you can get into the error loop thing that will let you open the earlier version by reverting to the previous
At least you can get into it again, but it likely will not save right and you have to do this every time
Maybe try the export from a lower level that I suggested above
Dunno
Just trying to help
Let’s get to the bottom of this
YES
YES
YES
Start from scratch
Dunno
Just trying to help
Thanks Duno for your feedback.
I'm pretty sure that this is something related to Moving Clusters / impoting snd te-importing scans (we are on a some thousand scans and re-organizing area distribution and so on...) but the problem comes up (we think) espetialy when we built the Project PointCloud and after this we need to add more scans and ... (unfortunately) we update that Project Pointcloud against to delete it and rebuild...
not sure but this helped to found problems...
for us inst impossible to come to RAW scans for the size of the project; instead we come back to a "non-Project Point Cloud backup that for the moment seems to dont produce too many problems...
tricky!!!
thanks again!!!
Lluis
tricky!!!
thanks again!!!
Lluis
- TommyMaddox
- Company Details: ONSITE3D
- Has thanked: 67 times
- Been thanked: 130 times
Do you have any points that are extremely far from the origin?
How about some scans that are preprocessed in a much earlier version of scene mixed with ones that are processed with the current version?
Sufficient temp and destination disk space for creating the project pointcloud?
After importing other projects, have you saved to finalize the import? This save will take a long time.
Hi Tommy:
answers about what you point (that effectively, are key points):
1.- points far away : not checked, but don't believe that they are more than 200m... coordinates are on the range of 0-1000 for the 3 axes
2.- scans processed in earlier versions... no: never we change versions of the software on the middle of a project (Scene 7.1.1.81 is the one used for that one)
3.- Temp space: yes, we use a 4Tb dedicated disc
4.- save after import: yes... and also createing the UPDATE project Point cloud... Personaly I think this is the point where we have the problem. Actually we recover an old version without Project PointCloud and re-do several processes (import subprojects, test re-filters and so on...) at the end of all of this we will save again and then create from CERO a new Project PointCloud...
hope this may solve the problem...
Ll.
Ll.
