Is there a way to just capture images with faro?
- I have made 50-60 posts
- Full Name: Jason Sturniolo
- Company Details: Architectural Firm
- Has thanked: 5 times
- Been thanked: 3 times
I was wonder if there is a way to just take the image part of a scan instead of the scan then the images. I have a client that all they want it the images.
Anyone know of a way to do this?
Thank you
Thank you
- TommyMaddox
- Company Details: ONSITE3D
- Has thanked: 67 times
- Been thanked: 130 times
Re: Is there a way to just capture images with faro?
Take a super low resolution scan with the image settings you want to save time, then in the newest version of SCENE you can export the full resolution color panoramas in 20,000 x 10,000 pixel compensated panoramic images. Doesn't completely eliminate the pointcloud, but it is probably the fastest way currently.
Thanks for the info. Will it still register them together at the lowest setting? Thanks again for the quick reply.
- ddustin
- Full Name: David Dustin
- Been thanked: 11 times
Jason,
The answer is... it depends.
You'll need enough overlap and point density.
You can always register it manually, but that will defeat the purpose.
Your original question was just about the images
David
David
You are correct with that.
Oh well I’ll continue doing what I am for now.
Thanks again.
- 3DForensics
- Honorary Member
- Full Name: Eugene Liscio
- Skype Name: eliscio
- Has thanked: 13 times
- Been thanked: 70 times
This has been a request from FARO for a very long time...
- Mortum
- Full Name: Robin van der Molen
- Company Details: ----
- Company Position Title: 3D Scanmonkey
- Country: Netherlands
- Has thanked: 3 times
Sounds like your client wants a google streetview kinda result.
Isn't it cheaper and faster to buy a dedicated 360 camera for that?
I make virtual tours with a Ricoh Theta S and my phone with the google streetview app. (I have a hobby business for photography)
Works like a charm!
If you want the Laser HDR effect, just add a freakload of clarity (in Adobe Photoshop or Lightroom) for the same effect
Works like a charm!
Sincerely, Robin van der Molen
Gear and Software:
Ye olde: Faro Photon 120
Faro Scene: 2023
Geomagic Design X
Autodesk Recap
Gear and Software:
Faro Scene: 2023
Geomagic Design X
Autodesk Recap
- I have made 70-80 posts
- Full Name: Ramon F Herrera
- Company Details: Free Open Source3D Model of Dealey Plaza
- Company Position Title: Founder - Chief Bottle Washer
- Country: US
- Has thanked: 8 times
Hi Eugene:3DForensics wrote: ↑Thu Aug 30, 2018 9:25 pm This has been a request from FARO for a very long time...
Thanks so much for your prompt and kind reply about the point cloud of Dealey Plaza and its processing with your Points2Cloud application:
http://www.clouds2max.com/
I have a related question which is definitely within your skill set, but since it is outside the scope of this sub-forum I will send you a PM.
Thanks again!
-Ramon
JFK Numbers
- 3DForensics
- Honorary Member
Thanks Ramon. There are some exciting things we are working on with Clouds2Max and hoping they will be available for posting by the end of October.
Cheers!
Eugene
Cheers!
Eugene
That is exactly what they need. Is there a way to stitch the 360 camera shots into something like scene does with web share 2 go?Mortum wrote: ↑Tue Sep 04, 2018 8:10 am Sounds like your client wants a google streetview kinda result.
Works like a charm!
Be very interested in reading more on how you use the 360 cameras.
Thank you
