Been doing a lot of plenum scanning. But the data just isn't great, mainly due to the excessive noise. Below screenshot is from RECAP. This is looking down on a fluorescent light fixture (ceiling mounted).
Is there a good filtering option for cleaning up this sort of data spray? Currently running Scene 5.2
Cleaning up data spray at ceiling mounted light fixtures
- berdindc
- Full Name: Dan
- Company Details: Berding
- Jason Warren
- Administrator
- Full Name: Jason Warren
- Skype Name: jason_warren
- Has thanked: 443 times
- Been thanked: 246 times
Re: Cleaning up data spray at ceiling mounted light fixtures
Hi Dan,
Have you tried using the SOR filter in CloudCompare?
Thumbnail Screenshots by Thumbshots
youtu.be/RjQPp2_GRnI
Co_Founder
LaserScanningForum
Co_Founder
LaserScanningForum
- berdindc
- Full Name: Dan
Have not tried Cloud Compare. Is it conducive to running on 150+ scans?
- Jason Warren
- Administrator
tbh I'm not sure if you can batch process 150 scans through CloudCompare GUI, but I think you can run CloudCompare in command line mode, so it maybe possible... when I get five I will take a look for you.
http://www.cloudcompare.org/doc/wiki/in ... _line_mode
Update
Found this thread, worth a try?
http://www.danielgm.net/cc/forum/viewto ... =SOR#p9403
Update
Co_Founder
LaserScanningForum
Co_Founder
LaserScanningForum
- richard_m
- Full Name: Richard Merrin
- Company Details: Fugro
- Company Position Title: Data Processor _ Project Engineer
- Country: Netherlands
Hi Dan,
it might be a little beyond Recap (Idk) but I woud suggest you need to crank up the 'Mixed Pixel' filter. LaserControl is pretty good at this but Cyclone and I assume Cloud Compare also.
Richard.
Richard.
- berdindc
- Full Name: Dan
Can Cyclone clean this up autonomously? I can export FARO --> e57 --> Cyclone for cleanup --> e57 --> RECAP.
I guess I'm down one step vs. 5 years ago??
- richard_m
Probably not. In Cyclone Navigator there's an important feature in the 'Edit(?)' pull-down called something like "Phase Based Scanner Import Filter Options', or similar, here you can set pretty good filters that can do a great job of cleaning up scans on import(IF you apply their values correctly). However this only works (as far as I'm aware) when importing raw scans from a narrow range of scanners (Leica HDS6xxx and HDS7000 plus z+f equivalents) so no Faro and no e57..
Anyone know if Cyclone can apply filters to imported data from other formats? I can't think and don't have Cyclone with me.
Richard.
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
In scene you can check Liber-d plugin. Check the comments in the forum, it looks like a killer app.
As an alternative export the fls files, import in recap and set filter to medium or aggressive, export back..
A check with you dataset will help to see if they are offering what you expect.
