RIEGL VZ600i
- Full Name: Dennis Hirota
- Has thanked: 87 times
- Been thanked: 379 times
RIEGL VZ600i
In case you have not seen the new Riegl VZ600i
youtu.be/CU5Q7DRUSd0
https://www.youtube.com/watch?v=CU5Q7DRUSd0
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
Re: RIEGL VZ600i
Looks brilliant. Again way ahead of it's competitors.dhirota wrote: ↑Tue Oct 18, 2022 7:18 am In case you have not seen the new Riegl VZ600i
Re: RIEGL VZ600i
Lieven
Please check it out on Wednesday at InterGeo 2022 and report back to us with your detailed observations.
- landmeterbeuckx
- Country: Belgium
Re: RIEGL VZ600i
I will Dennis, will take a few snaps and see what the fuss is about
I thought they were going to do a slam device but as they built a new scanner you surely see TLS isn't dead by any means.
Re: RIEGL VZ600i
I am sure you will report back to us, after you check it out.landmeterbeuckx wrote: ↑Tue Oct 18, 2022 7:51 amI will Dennis, will take a few snaps and see what the fuss is about
Re: RIEGL VZ600i
Additional information from Riegl News
My understanding is that the 6Kgm weight includes the dual batteries.
We need to check out the internal cameras, integrated GNSS and mobile mapping applications. Can we use an internal SIM card for RTK?
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Re: RIEGL VZ600i
Lovely looking piece of kit, it will be interesting to see the data and a bit more detail about what they mean when they say 'ready for mobile mapping applications'. If it had a vehicle mounting option similar to the Beemobile / Faro combination it would be very interesting indeed. That aside, it looks like a strong competitor to the RTC360.landmeterbeuckx wrote: ↑Tue Oct 18, 2022 7:51 amI will Dennis, will take a few snaps and see what the fuss is about
- JLarson
- Full Name: Jason Larson
- Company Details: VHB
- Country: US
- Been thanked: 25 times
Re: RIEGL VZ600i
With only a quick look, it looks like a nice scanner, but certainly not revolutionary, or "way out in front of it's competitors". The only thing I see that is an improvement over competitors is capturing photography and scan concurrently, cutting capture time down from 1'22" on an RTC360 to 30" at the same resolution and image capture. Yes, it's more than twice as fast, but for someone who started scanning doing 1.5 hour long scans, we're really slicing the pie thin here, where the reduction in scan time is at the point of diminishing returns.
A big issue for me is that it still has Riegl's limited 105° vertical field of view, that does not capture features directly above the scanner and leaves a huge hole beneath. For use in the building market where you are often working in tight, confined areas, this is a huge limitation in my mind. I'm sure there are technical design issues at work here, but it seems to me like Riegl started down this road a long time ago and has stubbornly decided that it's not an issue.
Jason Larson, PLS
