Exporting point clouds from Realworks
Discuss Trimble hardware here.
JamesRichards12
7
Full Name: James Richards
Company Details: Benchmark Surveys
Country: England
Post by JamesRichards12 »
Hi guys,
I need to export a point cloud from Realworks and import it into Autodesk Revit.
What is the best file format to save the exported point cloud as in order to import it into Revit?
James Richards
Benchmark Surveys
ecrowe
8
Full Name: Eric Crowe
Company Details: WM3D
Company Position Title: WM3D
Re: Exporting point clouds from Realworks
Post by ecrowe »
My preferred workflow is to export then entire project as PTX files and then import those into ReCap. Insert the ReCap file into Revit and you are good to go.
ChrisHarris
8
Full Name: Chris Harris
Company Details: Trimble
Company Position Title: Sales Account Manager - Geospatial EMEA
Been thanked: 5 times
Post by ChrisHarris »
Hi James, just spotted this so I'll get someone to give you a call and talk you through it.
RCP format might be the easiest.
RichardSelby
12
Full Name: Richard Selby
Company Details: KOREC Group Ltd.
Company Position Title: Training Manager
Post by RichardSelby »
Hi James,
For Revit you'll need to go via a Recap (RCP) file format. You can create an RCP project file directly from RealWorks if you have a licensed version of Recap running on the same PC as RealWorks. If not, then export an E57 file and import this to Recap. E57 is relatively compact in terms of file size. Regards, Richard.
vincent denis
11
Full Name: Vincent Denis
Company Details: GEOMESURE
Post by vincent denis »
Realy? What license do you mean? Recap pro? or any license. Because i have Recap on the same PC as Realworks but i dont find the RCP export
RichardSelby
12
Hi, I mean a purchased license for Recap Pro, version 3.0 and newer. Richard.
Muleymuel
7
Full Name: Sam Lynas
Company Details: PCL
Post by Muleymuel »
I am also having trouble with this. All latest versions of realworks and recap, with pro license and realworks recap plugin installed. I have tried uninstalling and reinstalling to no avail.
ANY IDEAS?
NAZEEM
5
Full Name: Nazeem
Company Details: Conserve Green Building and MEP Solution
Company Position Title: BIM Modeler
Country: India
Post by NAZEEM »
Hi brothers , I have lattest verson of Recap so i Export .rcp directly from the realworks thanks for the information, then while exporting like this i cant able to get panaromic image (realviews ) in Recap so please help to to solve this issues.
Geo Scan Surveying
6
Company Details: Geo Scan Surveying Solutions
Post by Geo Scan Surveying »
Have you tried exporting from within Registration mode? It used to be that the stations were preserved doing it this way but not entirely sure if this is still the case.
jpavlicek
5
Full Name: Jake
Company Details: Wood
Company Position Title: Survey Technician
Skype Name: [email protected]
Post by jpavlicek »
This seems to still be the case as of January 2024. I learned this the hard way after my export was running for days and still hadn’t finished. You can also export a structured RCP file to have the panoramic “bubble views” included in the RCP export. (Different option under the Export menu.)
Return to “Trimble”
