Registration Visual Check Tool
- Full Name: Richard Selby
- Company Details: KOREC Group Ltd.
- Company Position Title: Training Manager
- Country: United Kingdom
I've always used the Cutting Plane Tool in the past to run a visual check on a newly registered data set. However now I've had a look at the Registration Visual Check Tool in the Registration environment, it appears to be a good alternative. I like the way you can change the station colour easily should you need to.
- Full Name: Tom Card
- Company Details: LandScope Engineering Ltd
- Company Position Title: 3D Survey Services Manager
Re: Registration Visual Check Tool
I agree, we use it all the time for checking registrations. Easy to use and gives a good addition to the whole quality checking phase of projects.
We've generally found that trusting the numbers alone is not always sensible.
