Registration Visual Check Tool
Discuss all Trimble related issues here.
RichardSelby
Full Name: Richard Selby
Company Details: KOREC Group Ltd.
Company Position Title: Training Manager
Post by RichardSelby » Wed Jan 25, 2017 3:39 pm
I've always used the Cutting Plane Tool in the past to run a visual check on a newly registered data set. However now I've had a look at the Registration Visual Check Tool in the Registration environment, it appears to be a good alternative. I like the way you can change the station colour easily should you need to.
tomcard
Full Name: Tom Card
Company Details: LandScope Engineering Ltd
Company Position Title: 3D Survey Services Manager
Re: Registration Visual Check Tool
Post by tomcard » Wed Jan 25, 2017 3:58 pm
I agree, we use it all the time for checking registrations. Easy to use and gives a good addition to the whole quality checking phase of projects.
We've generally found that trusting the numbers alone is not always sensible.
Return to “Trimble”
