Good day.
I have recently upgraded the firmware on my RTC 360 to V4 and went scanning the next day. Once the scan was done I started with the Cyclone register Import of the project but once it is done I get an error message saying that reads "warnings/issues found during import : failed and skipped Setup" please see attached Picture.
It does not matter whether I do a partial import or everything at once. There is definitely point cloud attached to these files as you can see they have weight to them (+-500MB each) and i can view them on the scanner.
Has anyone run into this problem before and is there a solution for this?
RTC360 V4 Firmware Uploaded - Cyclone Register Problem
- Full Name: Pieter
- Company Details: Bilfinger Africa
- Company Position Title: Draughtsman - 3D scanning
- Country: South Africa
- Skype Name: pieter.barkhuizen
- Has thanked: 5 times
- I have made 40-50 posts
- Full Name: James Elson
- Company Details: SCCS
- Company Position Title: HDS Support
- Been thanked: 24 times
Re: RTC360 V4 Firmware Uploaded - Cyclone Register Problem
You will need to be running v2021.1.0 Cyclone to import the v4 RTC360 firmware.
- pburrows145
- Full Name: Paul Burrows
- Has thanked: 109 times
- Been thanked: 123 times
As James says, always ensure you are synced up with FW and SW versions... most likely this is the reason why.
- Full Name: Pieter
Hi Paul and James, if i log into my leica geosystems account i cant see the v2021 for cyclone register. Where else can i get the installation file for this?
- Full Name: joshua steinert
- Company Details: pb2 architecture + engineering
- Company Position Title: Graphics Manager
- Has thanked: 20 times
- Been thanked: 12 times
I have always downloaded Cyclone here:
https://leica-geosystems.com/en-us/prod ... ca-cyclone
If you cant access via Myworld then try below link:
https://portal.hexagon.com/blob/Downloa ... U6MzEgUE0=
Regards
James
- Full Name: Pieter
thank you i have downloaded and installed the ne version I now have a problem with my CLM it is not pulling my licenses through for Register and Model - I found this in the release notes -pburrows145 wrote: ↑Tue Apr 20, 2021 4:16 pm As James says, always ensure you are synced up with FW and SW versions... most likely this is the reason why.
Licensing
Cyclone 2021.1 is a major release. All users with currently valid CCP, or with CCP valid as of 22 February 2021, can run the latest version with no new license required.
I don't have a valid CCP available but i have permanent licenses for the above mentioned software - how do I request a new number?
- stevenramsey
- Full Name: Steven Ramsey
- Company Details: 4DMax
- Skype Name: steven.ramsey
- Has thanked: 30 times
- Been thanked: 72 times
In the clm check to see if there is any licenses that need activating. there would have been one for the new version
- pburrows145
You need a new CCP (at cost) from your local Leica distributor.Pieda wrote: ↑Wed Apr 21, 2021 10:15 amthank you i have downloaded and installed the ne version I now have a problem with my CLM it is not pulling my licenses through for Register and Model - I found this in the release notes -pburrows145 wrote: ↑Tue Apr 20, 2021 4:16 pm As James says, always ensure you are synced up with FW and SW versions... most likely this is the reason why.
Licensing
