Not sure if there is a simple solution or work around for this:
I have some scans taken with the RTC from a friends work shop where i carried out a small demo for him. The scans are a mix of intensity only and photos - as photos would not be required on all set ups in future jobs for them.
So when i export to LGS with TruView only (no point cloud), i cannot switch the image off to view the intensity only view. I can only switch the image off if the point cloud is exported which i dont want/need.
So is there any way, i can go from the photo view to view the intensity only as per the image below:
LGS Truview in JetStream Viewer
- steves01x
- Full Name: Steve Smith
- Company Details: Scanning
- Country: Scotland
- Has thanked: 31 times
- Been thanked: 57 times
- piotr.pioro
- I have made 30-40 posts
- Full Name: Piotr Pioro
- Company Details: P3D
- Country: Poland
- Has thanked: 8 times
- Been thanked: 8 times
Re: LGS Truview in JetStream Viewer
Hi all,
I am also wonering if there is a way to export .lgs without point clouds but in intesity mode. I can not find how to export without RGB color, anyone knows how to export .lgs without color value?
best,
Piotr
best,
Piotr
- pburrows145
- Full Name: Paul Burrows
- Has thanked: 109 times
- Been thanked: 123 times
I just double-checked this and only the colour image, HDR image and IR image (when using BLK360) are available when creating an LGS with no pointcloud.
I will speak to the PM team about this.
- steves01x
- Country: Scotland
Thanks - it would be very hand to be able to turn the image off to intensity only as per the example and if you have P40 data the quality from higher res scans is far better than the 360 image if zooming in to certain bits.pburrows145 wrote: ↑Thu Dec 10, 2020 3:04 pm I just double-checked this and only the colour image, HDR image and IR image (when using BLK360) are available when creating an LGS with no pointcloud.
While we are requesting things..
Site map: In Cyclone before creating LGS, create a 2 point slice through each floor to then create a site map per floor etc? So we would have the current top over view, then custom names such as Ground, 1st Floor, 2nd Floor etc? Be handy for larger sites/buildings.
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 767 times
- Been thanked: 148 times
The intensity views are only visible on the scan points themselves NOT on the Panoramic images. The IR values are assigned to pixels in the photos, that is why you can see the IR values on an image as well as the RGB. The RGB assignment from the panoramic overlay, intensity multi-hue and intensity Grey are part of the pointcloud DB not the Image DB. What Leica had done with an e57 export in the past (at least to Recap) was basically what you were saying. They create a "fake" panoramic which was basically a PICTURE of the Intensity colored Point cloud. That is not the case in Jetstream as it handles the points quite nicely without any lag. Perhaps that option will be one of their "improvements" in the future versions of JS viewer.steves01x wrote: ↑Wed Dec 02, 2020 2:41 pm Hi,
