Hi can anyone explain me the actual meaning of:
-> register 360
overlap;
Strength
Clou to Cloud
Bundle Error
-> Register
Error vector in Clou to cloud constraint (aligned x.xxx m)
In adition i ask where I can find some documents where these items are explained with some detail
Thanks in advance
Register & Register 360 -Registration statistics
- Full Name: Hugo Silva
- Company Details: TopoRigor
- Company Position Title: Engenheiro Geógrafo
- Country: Portugal
- Matt Young
- Honorary Member
- Full Name: Matt Young
- Has thanked: 45 times
- Been thanked: 40 times
Re: Register & Register 360 -Registration statistics
See my answers above.HDSilva wrote: ↑Sat Jun 15, 2019 5:56 pm Hi can anyone explain me the actual meaning of:
-> register 360
overlap; - Amount of scan data overlapping between two adjacent scans.
Strength - I guess this is based on a high or low amount of overlap.
Clou to Cloud - Where two or more scans are meshed together using the overlap and a cloud to cloud algorithm.
Bundle Error - The adjustment across the whole network.
-> Register
Error vector in Clou to cloud constraint (aligned x.xxx m) The residual error after a cloud to cloud fit.
Thanks in advance
- geomontgomery
- Company Details: ECE Design
- Has thanked: 20 times
- Been thanked: 48 times
Hey Silva, if you paste this link in your web browser, it will call up the help web page that installs with Register 360. There's a glossary which explains all the commands:
Code: Select all
file:///C:/Program%20Files/Leica%20Geosystems/Cyclone%20REGISTER%20360/help_manual/reg360help.html#gloss
- Country: Portugal
Thank you all,
It helped.
In the strength parameter I was trying to understand it numerically, the explanation in the glossary is a bit general, and not explains it very well, in my point of view
It helped.
- TimJervis
- I have made 80-90 posts
- Full Name: Tim Jervis
- Company Details: Global Survey
- Company Position Title: Business Development Manager
- Country: New Zealand
- Been thanked: 35 times
Hi Silva,
You can just press F1 while in the software and it will open up the help file straight away for any queries you have in future.
Tim
Tim
- Full Name: Eric Winkelman
- Company Details: FERASCO [forensic evidence]
- Company Position Title: Partner
Anyone know of a quantitative explanation? For the error, error vector, group error, group error vector? I think these statistics are used in Cyclone only. Some of the definitions just use the same word defined in the definition.
Aside, for Reg360 cloud to cloud I'm not sure what "matching geometry of point clouds" means.
I have unused training sessions with Leica. I will also try to get a more specific definition when I take the training some time in the next few months.
It would be useful for me to understand how I can change my field technique to improve the error statistics. And understand what error is acceptable. I recall being told less than 0.03 ft error is acceptable. Then there are results I don't understand such as when the error is 0.000. Absolutely 0 even if I increase the number of decimal places.
I've also learned that careful visual inspection of the registration is most important. I noticed in a project that one setup was misaligned by a few inches despite the error statistics being good.
