conversion of coe file to dxf files
- Full Name: ajaybabu
- Company Details: sayantrik engineers india pvt ltd
- Company Position Title: oil and gas designing company
- Country: india
when exported the dxf file from cyclone,the flanges are going to default layer.Any suggestion?....
- Country: india
- Phill
- Full Name: Phillip Nixon
- Company Details: SKM
- Has thanked: 7 times
- Been thanked: 45 times
Re: conversion of coe file to dxf files
I think there have been no replies cause you have given limited information
1.are you exporting a coe or a dxf from cyclone?
2. What program are you using to import the coe?
3. what layer were the flanges in in cyclone
4. What version of cyclone are you using
5 what version of coe transfer are you using
6. Are they inserted flange's or part of the piping routines
7. How about posting an example coe and dxf file so we can have a look for you.
We are happy to help, but your post was a little confusing.
Phill
Phill
- Country: india
1.exporting dxf file from cyclone.
2.directly importing coe file on cyclone.
3.flanges are piping layer.
4.8 and 9 versions.
5.8 and 9 versions.
6.flanges only.
7.we use yellow color in piping layer.after converted dxf file all flanges are converted to default layer and color(white).
https://www.dropbox.com/sh/4fk4w3gl8fn7 ... 3Se7a?dl=0
Please give me your valuable suggestions as soon as possible it so much require us.
Thank you.
4.8 and 9 versions.
5.8 and 9 versions.
6.flanges only.
Thank you.
- Phill
Ajaybabu
Ok, so I had a look at your data. You are correct, there does seem to be some bug in Cyclone where exported flanges via dxf don't hold their layers. However it works fine using a coe file. If you get the coe transfer utility from here
https://hds.leica-geosystems.com/en/29456.htm
the flanges will transfer fine and keep their layer using the coein tool in Autocad. They also transfer as 3d objects instead of Circles and polyface meshes.
Make sure to send a user feedback to Leica so they can fix the problem...hahahaha. In the help dropdown in cyclone there is a user feedback section.
See attached version of your coe imported into cyclone using coein.arx
Phill
Phill
- Country: india
- I have made 70-80 posts
- Full Name: Naveen
- Company Details: AROWANA SOFTWARE SOLUTIONS
- Company Position Title: Delivery Head
- Country: INDIA
- Skype Name: naveen.arowana
