Hi all,
Hope someone can help with this.
I'm Using the Alignment/Station Manager to extract road edges/kerblines fences etc along highways.
The way I'm doing it, is using Multipick on a point, then incrementing the station by 5m, after 300m I create a polyline.
This is working really well for me, except for when occasionally, when I select the next point it actually deselects one of my previously selected points. Is this a bug in the software? The points are not visible as I have a 100mm section, but it seems that because they're in the same position on the section plane, they get deselected sometimes. It's not that big an issue as it only happens every now and then... but its making a decent feature of the software slightly less... decent.
Any ideas? Am I doing something wrong?
Thanks.
Cyclone Alignment/Station Manager Issue
- andrew.grigg
- Full Name: Andrew Grigg
- Company Details: 40SEVEN
- Company Position Title: Senior Land Surveyor
- Country: England
- LeicaUK_RC
- Full Name: Phil Marsh
- Skype Name: Phil.H.Marsh
- Been thanked: 52 times
Re: Cyclone Alignment/Station Manager Issue
Hi Andy,
Are you only selecting one point on that section at any one time?
Are you using the template feature to extract the points?
- Full Name: Fabien
- Company Details: Amec Foster Wheeler
- Company Position Title: Geomatics Project Manager
Try to create a template of your road, then make adjustments as you move along. Never had an issues with it. I just hope that it would be more automated. Also make sure to have enough coverage left and right, up and down on your alignment. And you always can go backward, make adjustments.andrew.grigg wrote:Hi all,
Thanks.
- andrew.grigg
- Country: England
Thanks Phil... Yes, only selecting one point at a time. I think it may be coz I'm clicking too fast or something... but it does seem to just happen if the next point is in a similar position in the window.
Will try the template thing assuming that will let me select surveyed points rather than drawing over them?
Cheers Scan Ninja, yea I have no issues with viewing the section/adjusting it... it's just it seems to be deciding to deselect my selected points even if they're not visible in the view.
- Forum Supporter
- Full Name: Mark Francis
- Company Position Title: Geomatics Market Segment Manager
- andrew.grigg
- Country: England
Thanks for the videos and help. Is this the only way to use the Alignment tools then, with the drawing template and not using multi-pick?
I am preferring to use Multipick as when doing a lot of roads I feel potential for error is reduced since you can only select a surveyed point, it does mean doing one feature down one alignment, then repeating the process but I'm finding it really quick... but as I mentioned every now and then a previously selected point is deselected if it's in the same position.
It's hard to explain but I've recorded a little video... if you can manage to give it a quick look, keep an eye out on the distance between points per section, which should be around 5m... You'll notice that when he glitch happens (if that's what it is) the 5 will switch to 10, when a previous point has been deselected.
Hope this makes sense/it can be resolved... Or should I really just get on with the drawing template thingy and stop moaning? ha.
https://dl.dropboxusercontent.com/u/106 ... sue(1).mp4
Cheers if anyone manages to look.
- LeicaUK_RC
Hi Andy,
What about using the virtual survey feature whilst using the alignment and sections tools?
- andrew.grigg
- Country: England
Sorry for late reply Phil. Tried the virtual surveyor, still had a similar problem. It's probably user error or a tiny bug in Cyclone that only I'm bothered about... or maybe it's just my Cyclone version. I'll see if it still happens next time I do roads or after I upgrade Cyclone.
Thanks for your responses.
