Auto Add Constraints in Cyclone
DanielNMP87
Full Name: Daniel Neagu
Company Details: XYZ
Post by DanielNMP87 » Sat Aug 12, 2017 11:30 am
Hello guys,
My name is Daniel and I am a Noob ;)
I have a noob question for you: "why do i have to add auto add constraints every time i do a registration?" When i do a registration my error column is usually 0 mm I just think the auto add constraints in my case is unnecessary, or am i wrong?
Best regards,
Daniel
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Re: Auto Add Constraints in Cyclone
Post by Phil Marsh » Sat Aug 12, 2017 12:50 pm
HI Daniel,
Its not compulsory to do this every time but it will tighten up the registration by using the point clouds from each setup to strengthen the network. It can also be used as a gross error check for the control you have used. However, this largely depends on the data you've collected so not wise to run this on some projects i.e. tree's, etc.
When you cut slices through the data have you ever found any misaligned scans?
DanielNMP87
Post by DanielNMP87 » Sat Aug 12, 2017 3:19 pm
Hi Phil,
Thanks for the fast reply.
I usually take a few slices and everything looks fine i also trim as much noise as possible that's why i think its not always need like you said.
Also how do you get to level Faro scans in Cyclone? At my job I am supposed to import faro scans into Cyclone but i'm not really sure that said scans are leveled even though my colleagues think it's fine.
tbwester
Full Name: Thad Wester
Company Details: WeWork
Post by tbwester » Sun Aug 13, 2017 2:44 pm
the "0" errors are in some way fake. Once you auto add it connects all the possible constraints providing a better registration, but also the errors become more true to reality in the registration report.
We auto add on every project, unless there is a very specific situation where it does not make sense (due to noise or lack of overlap).
Importing FLS into cyclone are not level. They tilt artificially; a few inches over 100 feet.
DanielNMP87
Post by DanielNMP87 » Sun Aug 13, 2017 4:02 pm
Thank you, i understand know.
stevenramsey
Full Name: Steven Ramsey
Company Position Title: Technical Specialist Scanning EMEA
Skype Name: steven.ramsey
Post by stevenramsey » Mon Aug 14, 2017 10:41 am
It will depend a lot on how you have done your initial registration as to why you are getting a zero error (zero error usually means trouble in my book)
If you are using C2C and have registered the scans 1-2 2-3 3-4...... without creating any sort of cross links you will always get a zero error. there is no error but your data could end up looking like a banana especially as you are using unleveled data in cyclone. you will need your survey control and a few well placed targets to level it and move your data on to grid
It would be worth you contacting your local support and coming on a training course.
Steven Ramsey
Work steven.ramsey@leica-geosystems.com
Mobile +44 7766 310 915
DanielNMP87
Post by DanielNMP87 » Sat Aug 19, 2017 10:38 am
hello,
Thank you Steven for your advice.
I am using control targets for my registration also the faro scanner has been leveled in each scan onsite.
stevenramsey
Post by stevenramsey » Mon Aug 21, 2017 10:28 am
certainly sounds like you need some training. I can't see which company you work for, Feel free to contact your HDS supplier.
Steven Ramsey
