Z+F Laser Control vs Leica Cyclone
gabrio
Full Name: Gabrio Rossi
Company Details: Scan2BIM - R+TB Architetti Associati
Company Position Title: co-founder partner
Post by gabrio » Thu Apr 20, 2017 6:53 pm
Hi guy. We're happy owners of a Z+F Imager 5010 and we're looking for the best registration software for us, becouse now we have a licence of Laser Control Professional plus 8.5.4 that works only with target and upgrade it cost more than a new Cyclone licence. We'd like to register targetless and we want to be ready to manage hundreads of scans. What sw do you use with your ZF5010series/HDS7000 and why? Well, we know that using LSC we don't need to create the imp dbase (faster) but it looks like everybody use Cyclone. Ok, every opinion is welcome. We are confused about the right choice. Thanks
arch. Gabrio Rossi, MRICS
g.rossi@scan2bim.it
www.scan2bim.it
24121 Bergamo - Italy
+39.035.22.27.76
bdawood
Full Name: Bashar Dawood
Country: Calgary Canada
Re: Z+F Laser Control vs Leica Cyclone
Post by bdawood » Thu Apr 20, 2017 7:06 pm
I have a Faro scanner and use scene, I notice that it takes z+f, my projects consists of hundreds of scans in each project and use C2C, and it works just fine, you can try it for free for one month and see if it works for you, it has improved so much over the last few months.
Good luck
Wei Fang
Full Name: Wei Fang
Company Details: Huawei
Company Position Title: Algorithm expert
Country: China
Post by Wei Fang » Fri Apr 21, 2017 9:33 am
I recommend Autodesk Recap360 Pro.
I have tested it with about 150+ stations of Faro Focus X330.
The most important thing is: it's really cheap.
gabrio wrote:Hi guy. We're happy owners of a Z+F Imager 5010 and we're looking for the best registration software for us, becouse now we have a licence of Laser Control Professional plus 8.5.4 that works only with target and upgrade it cost more than a new Cyclone licence. We'd like to register targetless and we want to be ready to manage hundreads of scans. What sw do you use with your ZF5010series/HDS7000 and why? Well, we know that using LSC we don't need to create the imp dbase (faster) but it looks like everybody use Cyclone. Ok, every opinion is welcome. We are confused about the right choice. Thanks
steves01x
I have made 70-80 posts
Full Name: Steve Smith
Company Details: IIC
Country: Scotland
Post by steves01x » Fri Apr 21, 2017 9:56 am
I have only used Cyclone and Scene and would take Cyclone any day of the week over Scene as its far more stable (doesnt crash any where near as much), loads up almost instantly, it is more "complicated" but once you get going its actually easier to use and to find errors in the registration/QC. It also has the new smart align which is a massive time saver for going target-less.
I scanned a tricky ish building inside and out, 175 scans over 2 evenings as we had limited access, good field notes to load to smart align (original building plan and noted all scans then photographed the bit paper), i think it put the scans in to around 18 groups and some ungrouped, i spent less than 6 hours checking it / manually aligning each of the groups and additional scans together. Plus the pc time after each evening of scanning to import which i did when i was sleeping and the smart align was started before going out for food and done by the time i got back :D
Also depending on your work flow you have all the Jet Stream / Cloudworx plugin options.
One thing Scene does have over Cyclone is you can batch export all the scan worlds as separate registered scan worlds - Cyclone is a manual process for this.
gabrio
Post by gabrio » Fri Apr 21, 2017 7:04 pm
Thank you Bashar. Sorry but Scene it's not a choice for our workflow. Too many translation steps.
And thanks Wei: we have Recap Pro and we agree that it's an exciting piece of software, but you don't have any control. Probably this is the reason of the "exciting mood", it's a sort of bungee jumping experience ;-) Recap it's ok when we scan to BIM: we have a building and it's clear if there are some macro-errors. But we 're looking for a sw that you can use also in more generic laserscanning works, also whne it's difficult to visual control the alignment.
And thanks Smith: this is exactly what we need: some reliable QA/QC tools. Also the jetstream option (not now, for us) it's a plus for Cyclone. We use autodesk sw to design and model, so we just know how important is for the futeure development to be a market leader for the R&D budget.
Our question now is about the specific preprocess filter of the Z+F raw data and about the time you lose to create the imp dbase. But Cyclone it should be our choice.
No LSC fans around here?
thanks guys
g.rossi@scan2bim.it
www.scan2bim.it
+39.035.22.27.76
bdawood
Post by bdawood » Sat Apr 22, 2017 12:44 am
I do hear lots of good news about cyclone, maybe I should try it, to get comfortable it will probably take a month. I should seek a free trial.
Rjw
Full Name: Ryan walker
Company Details: Veerum Inc
Company Position Title: Geospatial Engineer
Post by Rjw » Sun Apr 23, 2017 6:05 pm
anonimou
Full Name: Delio Pontes
Post by anonimou » Sun Apr 23, 2017 9:08 pm
I work with both, but for registration only Cyclone.
I use laser control only to filter, colourize the Z&F scans and to check the scanner.
I dont know if cyclone registration is better but was always our main software for point clouds.
Other good thing that we use Cyclone is to make a 3D Rotation of our total station control before we start the registrations.
For example, control on offshore platforms needs to be adjusted because of the platform movement and cyclone do a very good "best Fit".
jorgenspetz
Full Name: Jorgen Spetz
Company Details: SP Swedish Technical Research Institute
Company Position Title: Technical manager Geometry
Country: Sweden
Post by jorgenspetz » Tue Apr 25, 2017 7:53 am
Hi Gabrio,
We work with both of them too. Worked a lot more with Cyclone, still feels like I have more control, and are able to tweak the last mm. We have only LC Scout as of now, and not the full plane check version. But LC Scout is really doing a good job, especially considering your own effort is so small. We are using it more and more. If it had some proper loop closure I think it would have been really great. Have not had any problems with large projects.
Sorry, can't help in deciding, we kinda like both of them. ;-)
richard_m
Full Name: Richard Merrin
Company Details: Fugro Geoservices
Company Position Title: Data Processor _ Project Medewerker
Country: Netherlands
Post by richard_m » Tue Apr 25, 2017 8:31 am
I'm the same as the above two posts. I use both but I just kinda get a better 'feel' of where my reg is stressing and where issues lie when using Cyclone. Saying that, LC is far better for filtering data (.zfs in particular), checking scanners and of course colouring 5010c data.
Recap is fine if you don't know anything about ACCURATE scan registrations or want to, all very 'Teletubbies go Scanning'.
Richard.
