LiForest (LiDAR software for forestry applications) provides a platform that enables users to freely manipulate the LiDAR point cloud and extract useful information specially for forest studies. It consists of several primary modules for LiDAR point cloud data processing, including point cloud visualization, LiDAR-based forest metric calculation, digital model generation, regression models and individual tree segmentation.
You can get more information about LiForest by visit the website: http://www.liforest.com/
LiForest
- Full Name: Lynne
- Company Details: ibcas
- Company Position Title: Beijing China
- Country: China
Re: LiForest
LiForest(LiDAR software for forestry applications) provides a platform that enables users to manipulate LiDAR point clouds and extract useful information for forestry applications. Here is the comparison between LiForest and some other related professional software.
LiForest
LiForest(LiDAR software for forestry applications) provides a platform that enables users to manipulate LiDAR point clouds and extract useful information for forestry applications. It consists of several primary modules for LiDAR point cloud processing, including point cloud management, LiDAR data filtering, forest metric calculation, digital elevation and surface model generation, regression models, and individual tree segmentation. The core algorithms of LiForest have been published in many peer reviewed scientific journals, and our LiDAR algorithm has received an award from the American Society for Photogrammetry and Remote Sensing.
You can download the trial version from the website: http://www.liforest.com/
Terrasolid
Terrasolid software package is used for processing airborne and mobile LiDAR data and images. It can be used for data calibration, point classification, image processing, position validation and delivery product production. Terrasolid applications are built on top of Bentley products.
https://www.terrasolid.com/home.php
Quick Terrain Modeler
Quick Terrain Modeler is a 3D point cloud and terrain visualization software. Quick Terrain Modeler allows users to visualize 3D points, generate digital models, edit both point clouds and DEM.
http://appliedimagery.com/
FUSION/LDV
FUSION is a LiDAR data analyze and visualize software. This software consists of: FUSION, LDV and a set of command line programs. The FUSION is the user interface for 2D display, LDV provides the 3D visualization, command line programs provide data analysis and process functions, including conversion, filter, compute statistic parameters etc.
http://forsys.cfr.washington.edu/fusion ... atest.html
CloudCompare
CloudCompare is a generic 3D point cloud data editing and processing software. It provides a set of tools for projection, registration, distance computation, statistics computation and segmentation on point clouds.
http://www.danielgm.net/cc/
SAGA GIS
SAGA provides several modules for point cloud processing, import/export, conversion, tools(point cloud cutter/thinning/transform etc), analysis(cluster analysis for point clouds, point cloud reclassifier etc), visualization(a 3d viewer for point clouds).
http://www.saga-gis.org/en/index.html
LiDAR Analyst
LIDAR Analyst® is a LiDAR software extension for ESRI ArcGIS, it is designed for feature extraction for airborne LIDAR data. It can be used to manipulate, filter and edit point clouds, and provides an end-to-end feature extraction solution.
https://www.overwatch.com/products/geos ... ar_analyst
LP360 for ArcGIS
LP360 for ArcGIS is a LiDAR software extension for ESRI ArcGIS as well as a standalone version for Windows. LP360 provides tools for point cloud statistics, create 3D breaklines, point cloud classification and building outline generation.
http://www.qcoherent.com/products/index.html
MCC-LIDAR
MCC-LIDAR is a command line tool for LiDAR data classification using the Multiscale Curvature Classification algorithm, it is designed for forest environment.
http://sourceforge.net/apps/trac/mcclidar/
VRMesh Survey
VRMesh Survey is designed for automatic point cloud classification and feature extraction. It provides comprehensive functionalities to extract vegetation, buildings and ground points from airborne and mobile LiDAR data, extract building footprints and create 3D building models, detect railways and curbs, generate grid surfaces.
http://www.vrmesh.com/products/survey.asp
FugroViewer
FugroViewer is designed for data view and analyze. It can be used for various types of raster- and vector- based datasets, including data from photogrammetric, LiDAR and SAR sources.
http://www.fugroviewer.com/
LiForest
Terrasolid
FUSION/LDV
CloudCompare
SAGA GIS
LiDAR Analyst
LP360 for ArcGIS
MCC-LIDAR
VRMesh Survey
FugroViewer
