Removing people from WebShare views
- berdindc
- Full Name: Dan
- Company Details: Berding
- Company Position Title: Project Engineer
Sensitive client, does not want people to be in the SCENE Webshare view. Removing the 3d points does not seem to carry over to the web-share view.
Is there a way to blur faces or otherwise make folks unrecognizable??
- I have made 40-50 posts
- Full Name: Bobby Fenttiman
- Company Details: Private
- Company Position Title: Revit operator Trainee
- Country: uk
- Has thanked: 4 times
- Been thanked: 2 times
Re: Removing people from WebShare views
Export images out > photoshop > Reimport is all I can think off. Otherwise use the picture retake option if available on the scanner at the time of scanning.
- berdindc
- Full Name: Dan
I did not capture photos. So these are all B&W "images" created from the point cloud. I was hoping there was an option with Webshare itself to create a text box.
- MarkJLane
- Full Name: Mark Lane
- Company Details: Faro Technologies
- Company Position Title: ANZ Account Manager
- Has thanked: 25 times
- Been thanked: 43 times
I've had this come up on a large project recently - unfortunately I couldn't find any reliable automatic tools for this, so the images were tediously blurred manually in Gimp. Motivated to never repeat this exercise, I've set about developing a tool to automatically blurr faces using machine learning.
I'll post any updates to this thread.
- berdindc
- Full Name: Dan
350 scans here, so I can imagine the pain. The odd thing is, with the 130x is that it inverts skin colors! I don't understand that.
- Full Name: Major Domo
- Company Details: VeritasVfx
- Company Position Title: ceo
- Country: Portugal
- Has thanked: 17 times
- Been thanked: 53 times
- steves01x
- Full Name: Steve Smith
- Company Details: Scanning
- Country: Scotland
- Has thanked: 31 times
- Been thanked: 57 times
If its intensity, can you cut the people out in each of the registered scans, export them all then re-import? Then create the webshare.
- 3DForensics
- Honorary Member
- Full Name: Eugene Liscio
- Skype Name: eliscio
- Has thanked: 13 times
- Been thanked: 70 times
When you create the Webshare, just dig into the root folders and pull up the pano images that are being used. No need to export from Scene. Take those images into any image processor and blur the faces. Yes, it will be manual, but so long as you don't change the format of the image and simply re-save with same name in same location, you can do whatever you want to the image. I tried this a long time ago by swapping some images and it worked so although I haven't tested this particular workflow, I don't see why it wouldn't work.
Eugene
Eugene
- Full Name: Jed Frechette
- Company Details: Lidar Guys
- Has thanked: 62 times
- Been thanked: 220 times
I haven't used any of them so can't make any recommendations, but there seem to be quite a few automatic tools for doing this sort of thing on photos. Just one example from my first page of search results:
https://github.com/understand-ai/anonymizer
Jed
- I have made 30-40 posts
- Full Name: Martin Heide
- Company Details: FARO Europe GmbH
- Company Position Title: Senior 3D Software Engineer
- Been thanked: 3 times
Another (manual) way to do this is using the Quick View or Planar View in SCENE.
Disadvantage: This will make the area black in the image, instead of blurring it.
Advantage: This will also delete the 3D information of the selected area.
Set the values to Min = Max = 0.
After modifying the scans, do another SCENE WebShare Cloud export + upload.
Find more material in the FARO Knowledge Base:
- Open Quick View or Planar View on the scan.
- Create a selection, e.g. using the polygon tool.
- Right click on selection > Scan Points > Delete.
