Rookie TrueView User, Cyclone Exports
3DUserNet, Cintoo, GeoSignum Pointer, Pillr, Pointbox, Pointerra, Pointly, PointSharePlus, Pythagoras, Potree, Vercator, WebShareCloud, Etc.
alib88
12
Full Name: Alison Bentley
Company Details: WSP
Post by alib88 »
Hi All,
Rookie user so please excuse basic questions.
I am wanting to export a 'cleaned' TrueView from Cyclone for clients to make mark ups.
As many of our sites are structures (e.g. bridges) in rural settings I am essentially wanting to strip out any vegetation to make the structure more visible for them. However it doesn't seem to matter which set of data I clean up/segment/select/create new modelspace of, it will always export the 'uncleaned' version to TrueView. Is this always the case? How can I just get it to just export what you see on screen!
So basic but I just cant seem to fathom it!
Any help much appreciated
Ali
Bill-Wallace
14
Full Name: Bill Wallace
Company Position Title: HDS Sr. Software Product Manager
Re: Rookie TrueView User, Cyclone Exports
Post by Bill-Wallace »
I think you need to "Set Default Cloud". With Cyclone you never really delete any points, you just create various versions of the clouds in a sense. So you need to set the default cloud to use for publishing, export, etc.
Disclaimer: This is just my highly educated guess. Also, I don't know exactly "how" you set default cloud. Maybe someone else can confirm and provide exact details exact details. I am the product manager for Cyclone but not the most technical user.
I'll try to get someone to confirm and explain.
dlangley
14
Full Name: David Langley
Company Position Title: Applications Engineer
Post by dlangley »
Bill is correct, sounds like you need to set the cleansed cloud as default. That can be found under Tools>Scanner>Set as Default Cloud. After you do this, open up the TruSpace for that ScanWorld and it should reflect your changes. You may need to go to File>Reset TruSpace for your changes to take effect. TruViews get published from the TruSpace, so what you see there is what will get published.
Hope this helps.
alib88
12
Post by alib88 »
Hi Bill and David,
Thanks for your replies.
I have the option to set default clouds and so have done so. However I don't seem to be able to open any TruSpaces (the option is there but 'greyed out') and the option you suggested 'File>Reset TruSpace' doesn't appear to exist for me either. I am running 7.4.1.
Setting the default cloud appears to work for the site map but doesn't translate through to the scan positions which still include the full dataset.
Would you have any other suggestions?
Ali
Honorary Member
Honorary Member
16
Has thanked: 45 times
Been thanked: 40 times
Post by Matt Young »
Once you have done the clean-up in the control space for each scan you can unify the data. Removing data only masks it - unifying goes one step further.
72RPG
9
Full Name: Juraj Knotek
Company Details: BAM Contractors
Company Position Title: BIM Technician
Skype Name: knotek72
Post by 72RPG »
hi,
only one question:
after cleaning data - it will be OK in TruVIew? (no black areas?)
Because cleaning will do this with RealView for ReCap.
(I did not try it in Cyclone, no need for cleaning/too lazy :))
juraj
Return to “Web Based Software”
