FARO WebShare v2.13 has been released on March 25, 2021.
We proudly announce the new features:
New Features & Improvements
[Demo Video below] Users can now use Clipping Boxes to clip point clouds in WebShare's 3D view.
You can create a temporary clipping box in the action menu, or persistent ones in the new task.
Clipping boxes support all the usual object properties, such as description and category.
Exporting and importing clipping boxes will be added to SCENE 2021.0 (coming soon). Try out the Clipping Box feature in this Example Project.
[Screenshot below]Attach Files: Users can now upload arbitrary files and attach them to annotations or other workspace objects.
In the Take Orthophoto task, the Data Type selection was added.
You can now choose to create the Orthophoto from 3D point data instead of scans.
This may increase the visual quality, e.g. due to more uniform colors.
It also makes it possible to create an Orthophoto from mobile scanning data like the FARO Focus Swift where no scans are available, or from a point cloud that was added to the project later.
Users can now change their WebShare login password directly from the Account Settings page.
You no longer have to wait for the password reset email.
[WebShare Pro feature] The Export task now shows a warning when the selected volume is too large, and the export is unlikely to succeed.
Other
WebShare no longer works with Internet Explorer 11.
We advise all affected users to switch to one of the supported browsers.
Removing support for deprecated browsers allows us to focus our efforts, and to deliver the best user experience on modern browsers.
Regarding the new file upload feature, some users may find the low file size limit of 128 MB inconvenient. We have worked on this in the last weeks and implemented the necessary adjustments to increase the file size limit to 5 GB. That should be plenty for almost every use case. If everything goes according to plan, we will be able to publish this improvement soon.
Both the file upload and the clipping boxes are features that I personally spent a lot of development time on. I believe that the clipping boxes are among my best work yet. It’s amazing how quickly and fluid they respond to changes in the clipping menu if you consider that it’s a web application. I therefore find it a real joy to use them.
Senior software engineer working for FARO on WebShare, SCENE 2go, and related products.
My webcomics: Sandra and Woo, Gaia.
WebShare v2.13.1 has been released on June 17, 2021.
[WebShare Pro feature] Point cloud exports in the RCP and POD formats are now significantly faster.
The Project Overview and Project Management pages now show how often each project was viewed by users.
The Attach Files feature now allows to upload files larger than 128 MB.
The owner of each paid WebShare domain now receives a monthly usage and cost report email. (To ensure that you receive these reports, please verify that the correct domain owner is set for your WebShare domain: Administration > Settings > Domain > General Settings)
Find the full release notes on the News page of the user manual.
I have a ton of issues creating/uploading Webshare Cloud on large jobs. More than 100 scans, it is high unlikely to succeed. Is this a limit on FARO's end? Is there something I am doing wrong?
berdindc wrote: ↑Mon Nov 01, 2021 4:27 pm
Olivier,
Q: What can I do when the WebShare Cloud export of a project fails?
A: Probably the most promising approach to save a WebShare Cloud export that fails during the creation of the overview map is to use the “SCENE Overview Map” map type in the export dialog since the process used for its creation is much simpler. The result resembles a clear view map in black-and-white.
There are some other possibilities for increasing the probability of success (best used in conjunction):
(Re)Generate a project point cloud before the export so that it is used instead of the scan point clouds.
Restart Windows, start SCENE and immediately begin the export without having any other programs open so that the maximal amount of free memory is available.
Disable generating the scan layers in the export dialog if you don't need them.
Use the Standard View in the export dialog instead of Clear View or Gap Filler.
If all of this fails, try the export on another PC. Split the project into smaller sub projects and export them separately.
Scott Karlins
Technology at Large
FARO Certified Trainer
(678) 990-3280 ext. 6025 Fax: (678) 990-3285 Mobile: (770) 338-9946 http://engsys.com
Engineering Systems Inc.
