Webshare/TruView Replacment
Truview, Potree, Octree, VRML, Etc.
TommyMaddox
Full Name: Tommy R Maddox III
Company Details: BC Engineering and Design
Company Position Title: Engineer I
Re: Webshare/TruView Replacment
Post by TommyMaddox » Thu Oct 06, 2016 2:28 am
It was surprisingly simple. PM me.
droneflyer
Full Name: Kevin Guthrie
Company Details: DiCarlo Precision Instrument
Company Position Title: Technical Specialist
Post by droneflyer » Fri Mar 03, 2017 12:06 am
TommyMaddox wrote:It was surprisingly simple. PM me.
Tommy...
I'm very interested in how to enable Webshare2Go for internet users. I tried to make it work several versions ago with no success. Can you PM me? I am a new member and can't send PMs yet.
Thanks!
TommyMaddox
Post by TommyMaddox » Fri Mar 03, 2017 1:27 pm
Basically every time you export a webshare 2 go project, it bundles the project data with chromium portable and all of the html partials and whatnot to run the webshare 2 go platform. It also includes the interface bits for the webshare cloud platform, but not all the back-end bits that you actually need to run a server version of webshare cloud.
Anyways, you need to use either something like XAMPP with an apache host, or even the "Web Server for Chrome" extension. Point the root directory at the folder in which your webshare 2 go project is stored. Then you need to ensure that your port forwarding/static IP/Dynamic DNS settings are correct to allow internet users to access the web app. If you've set up a SCENE 5.5 era Webshare server then this will be no stranger to you.
So now you have a webshare 2 go instance that can be accessed over the internet.
You still don't have logins, or the extra cloud functionalities, but this is acceptable for public project access and marketing efforts.
It isn't too hard to add login functionalities if you modify one of the html partials and can handle a little php/sql. The easiest approach is to run one instance of webshare 2 go for each desired user, and segregate the data in that method. There are better ways to accomplish this, but if you don't want to dig into the code too much, this is the easiest.
When you need to add projects to the webshare 2 go server data files, drop the data folder of the generated project (its in the ws2go data folder) into the data folder of the project that is being used by the server, and append the projects.json to include the new folder name so that it will show up on the interface when accessed.
If you need a more thorough step by step walk through, you can call me at 803-528-0649.
You can my version at:
http://webshare.bcengineeringanddesign.com/
MALTBY
Full Name: Simon Judd
Company Details: MALTBY LAND SURVEYS
Post by MALTBY » Fri Mar 03, 2017 1:56 pm
Websharecloud is an excellent service as far as we are concerned. Easy to use, powerful functionality for both internal and external client use.
Currently have over 450 projects online with over 3.3 terrabytes of hosted data.
Simon
jochenstier
Full Name: Jochen Stier
Company Details: Geist Software Labs
Company Position Title: Founder
Skype Name: jochen.stier
Post by jochenstier » Thu Mar 09, 2017 9:57 pm
I would like to throw http://www.voxxlr.com into the mix here as well. The rendering and hosting infrastructure is in place and measurement as well as annotation tools are under development. Here is a link to the latest viewer. You can use the card on the top left to select different viewpoints and the control points of the measurements are live, i.e. you can move them around. You will get the best performance out of Chorme of FireFox, then MS Edge. Unfortunately it does not yet work on Safari:
http://www.voxxlr.com/share/hxMukpcQWuZ ... lM1drw9luM
The above link contains a scan inside the viewer which you would send to a client. You can upload scans and create the measurement/viewpoints at http://www.voxxlr.com. The next step is to create data bindings to various Asset Management Databases and public information sources such as weather information etc.
If you have any particular feature request, please let me know. Voxxlr is still in beta for now, so it is free and we are always looking for pilot projects to participate in. The development is quite active and we will respond quickly to requests that would make Voxxlr more useful.
RSteffen
Full Name: Richard Steffen PhD
Post by RSteffen » Fri Mar 10, 2017 11:49 am
the new webexport in PointCab in 3.6 does not need a flash or other plugins anymore. Its pure HTML5 based and works on any handheld/mobile phone to.
Have a look to this example:
http://update.point-cab.com/demo/NewWeb.html
Richard
Post by Jason Warren » Fri Mar 10, 2017 2:08 pm
RSteffen wrote:Hi,
Richard
Nice bike Richard... ;)
#ThePowerofLSF
Return to “Web Based Software”
