Cross-section color in polyworks
cwxTools, Euclideon GEOVERSE, SOLIBRI Model Checker, BCF, ScanManager, GreenSpider, GeomaticsCUBE.
foobarbecue
Full Name: Aaron Curtis
Company Details: New Mexico Institute of Mining and Tech.
Company Position Title: PhD Candidate
Post by foobarbecue » Wed Oct 01, 2014 6:32 pm
Try as I might, I cannot get control of the color of cross sections produced by IMSurvey in (PolyWorks V12).
The cross sections first assume to color of the object from which they are created. Then, when I create a Data Color Map using the "Measure Deviations" tool for any, totally unrelated object, all of the cross-sections in the project turn grey. Color settings in the cross section properties, original object properties, and tools/options/display/cross-sections appear to have no effect. (OTOH, changing "line width" DOES have the expected effect.)
Other IMSurvey users: are you experiencing this problem? Is there a solution or workaround?
NOVAMECH
Full Name: Nick Bush
Company Details: NOVAMECH
Country: New Zealand
Skype Name: novamech5
Re: Cross-section color in polyworks
Post by NOVAMECH » Thu Oct 02, 2014 11:39 am
You need to expand the Feature Tree under the cross section - Then right click Properties - Then change the colour, As below
Interestingly. I scanned this with the DPI-7 Tablet Imager today
It took 1 minute - and the results were not bad. Looks like the cross section has come out quite well.
This was scanned in day light - with cloud - But the unit still works. I was warned that this would not work in direct sunlight. It was still not a bad day. But not bright blue sky.
I may take some cross section of a small yacht hull over the weekend and see how a model comes out.
If anyone can help getting DPI-7 data into ImAlign I would be very grateful.
foobarbecue
Post by foobarbecue » Mon Oct 06, 2014 5:06 pm
NOVAMECH wrote:You need to expand the Feature Tree under the cross section - Then right click Properties - Then change the colour, As below
Thanks, but this is what I was trying originally and it has no effect. It works fine at first, but once you create a deviation color map somewhere in the scene, all cross sections become grey all the time. For example, in the attached image, I have one of the visible cross sections set to red, but it's still grey.
NOVAMECH
Post by NOVAMECH » Wed May 20, 2015 11:07 pm
You might like to try changing the "Object Colour Mode"
Return to “Third Party Software & Plugins”
