I regularly get requests about our converter that also displays information on e57 files. So, the best is to share it with the whole community.
Here's the public link:
https://drive.google.com/open?id=18AXZg ... nRZIT5wxE6
Actually this is the beta version of our converter that transforms e57 into our internal format, but it also contains a feature that allows checking the e57 structure.
Add your e57 files, highlight the desired file, and then click on "Show details". The right panel will display the e57 structure. No need to load the e57 first.
Hope it helps!
e57 analyzer
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 181 times
- Been thanked: 544 times
Re: e57 analyzer
Hi Yan,
I've tested with an e57 from faro and this worked. Also an e57 from Pointcab.
With a e57 from Riegl the software crashes. I did a ptx from Riegl to Pointcab and then a E57 and this also worked.
- Jason Warren
- Administrator
- Full Name: Jason Warren
- Skype Name: jason_warren
- Has thanked: 439 times
- Been thanked: 241 times
Re: e57 analyzer
Niceone...
Co_Founder
LaserScanningForum
Co_Founder
LaserScanningForum
- Full Name: Scan ku kaï
- Company Details: Scankukai
- Company Position Title: CEO
- Country: France
- Has thanked: 58 times
- Been thanked: 207 times
Re: e57 analyzer
Hello Lieven,
On this beta version, converting the scans may fail depending on the software used to export the e57. The Riegl issue will be fixed soon.
So, please don't try to convert the scans.
But the e57 information should work:
