Hi Friends.
I am looking for a software suitable for extracting a rail, cross sections and parametters (alingment, slope, camber,....) of the via form a point cloud.
I saw some softwares but it seems they are focussed on train rail. I my case I need to extract the parameters of a via of a bridge crane where the rails are separated around 10 metters.
Do you have any experiece in this issue.
Any recomendation.
Thank you in advance.
Rail extraction from Point clouds.
- JADominguez
- Full Name: José Antonio Domínguez
- Company Details: Metromecanica
- Company Position Title: Láser Scanner head of the project
- Country: Spain
- Been thanked: 3 times
- smacl
- Has thanked: 626 times
- Been thanked: 655 times
Re: Rail extraction from Point clouds.
We've automated rail extraction tools in SCC, see the video below for an example. While it is commonly used in conjunction with trains there is no reason why it should not work with much wider gauges. If you want to send me a sample dataset over I can check how well it works and organise a trial license.JADominguez wrote: ↑Wed Dec 18, 2019 1:57 pm Hi Friends.
Any recomendation.
youtu.be/c5QorfYnw2g
- JLarson
- Full Name: Jason Larson
- Company Details: VHB
- Country: US
- Been thanked: 25 times
TopoDOT has an excellent semi-automatic rail tool that is very flexible and can certainly be used for this purpose.
Jason Larson, PLS
- JADominguez
- Country: Spain
Hi smacl, thank you very much for your answer.smacl wrote: ↑Wed Dec 18, 2019 3:03 pmWe've automated rail extraction tools in SCC, see the video below for an example. While it is commonly used in conjunction with trains there is no reason why it should not work with much wider gauges. If you want to send me a sample dataset over I can check how well it works and organise a trial license.JADominguez wrote: ↑Wed Dec 18, 2019 1:57 pm Hi Friends.
Any recomendation.
It looks really nice. ow can I send you a sample with the data? Also I would like to test it myself.
Thank you again.
JA
- JADominguez
- Country: Spain
Thank you JLarson,
I will check the possibilities of TopoDOT for this work.
A greeting.
J.A
- smacl
Hi JA,JADominguez wrote: ↑Thu Dec 19, 2019 8:15 amHi smacl, thank you very much for your answer.
Thank you again.
JA
This link contains instructions on downloading the latest version of SCC. If you send me some sample data using a service like https://wetransfer.com/ or FTP to [email protected] I'll check how well it works in SCC and send you some step by step instructions or short video of the steps required,
All the best,
Shane
