Good morning, I wonder can anyone explain to me and pardon my lack of understanding.
Why is it when I have created a nice floor plan in AutoCAD from my point cloud and think yes this is working out well, to realise that when I save and go out of AutoCAD and open the drawing at a later date that the line work created and point cloud are then mis aligned significantly.
Appreciate any theories, facts whether obvious or complicated.
Leinster
Draughting using pointcloud in AutoCAD
- I have made 60-70 posts
- Full Name: Giovanni Scocchera
- Company Details: Meridian Design Associates
- Company Position Title: Designer
- Has thanked: 41 times
- Been thanked: 4 times
Re: Draughting using pointcloud in AutoCAD
Can you send a screenshot showing the problem? Before and after?Leinster wrote: ↑Tue Feb 11, 2020 7:51 pm Good morning, I wonder can anyone explain to me and pardon my lack of understanding.
Leinster
Ciao,
Gio
- Full Name: James Worrell
- Has thanked: 14 times
- Been thanked: 87 times
MGA coords by chance?
Haven't really seen issues with Autocad - but we usually link in via Cloudworx as opposed to Recap. Autocad and Recap don't really like MGA coordinates all that well - osnap etc especially. The linking in could be a more recent issue.
If on MGA - try truncating.
- Full Name: Amanda Li
- Company Details: CRA Survey
- Company Position Title: Graduate Surveyor
- Has thanked: 5 times
- mariusP
- Full Name: Marius Putrimas
- Company Details: Terra Modus
- Company Position Title: Undet product manager
- Country: Lithuania
- Has thanked: 30 times
- Been thanked: 45 times
Native AutoCAD with Recap is really poor with coordinates transformation, you should always use point cloud locking to avoid accidental movement of the point cloud block..Leinster wrote: ↑Tue Feb 11, 2020 7:51 pm Good morning, I wonder can anyone explain to me and pardon my lack of understanding.
Leinster
typically when you inserting the RCP file it will be not locked, and you can accidentally move it during vectorization. Select point cloud go to properties and check "Locked" to yes. Also check with which settings you importing point cloud files, with different settings you can import in a different place... As I remember this problem is from the beginning of point cloud support from 2009... Better work with AutoCAD plugins, which will speed up workflow and elimante such problems.
P.S.
https://youtu.be/BxWeAv5rr5Q - you can view this video on how to draw floor plan from point clouds using Undet.
Undet Point Cloud Software provides software solutions for AutoCAD, ARES Commander, Revit, and SketchUp point cloud users to save time, increase efficiency, and reduce errors in creating 3D models and 2D drawings.
www.undet.com
www.undet.com
- Full Name: Paddy Kenny
- Company Details: Keltic Surveys Pty Ltd
- Has thanked: 13 times
Thanks for the feedback. Yes the point cloud wasn’t locked which created the mis alignment, luckily I had a back up of the original which had 95% of the line work intact and aligned.
