AutoCAD and Cloudworx - Isuues
AutoCad, MicroStation, ZWCAD, ARES, GstarCAD, 4M, IntelliCAD Etc.
safib
Full Name: Santo FB
Company Details: Rdots
Post by safib » Thu Apr 13, 2017 10:16 am
I would like to share my problems whit AutoCAD 2016 and Couldworx 6.0.3, maybe some users have the solution.
I have 3 machines with:
- SSD
- CPU INTEL i7-5820K - I7 6700K
- VGA NVIDIA 970 AND 960
- WIN 10
- 8/16GB DDR4
Everyday we doing 2D/3D stuff with AutoCAD and CloudWorx.
We are so tired of the follow problems:
1. Crashes... many crashes.
2. When We activate cloudworx autoCad stop to combine Pan/Zoom command and We need to Undo several time just to delete a line.
Code: Select all
Command: _pline
Specify start point:
Current line-width is 0.0000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
[b]Command: _u OLEAPPLICATION
Command: _u
Command: _u INTELLIPAN[/b]
Command: _u Polyline GROUP
I try to ask help to Leica but I so difficult get back answer.
Someone is afflict by this kind of issues? Someone have a solution? Maybe the problems is my hardware but, in my opinion, should be good enough
mwb
Full Name: Mark Benjamin
Company Details: Leica Geosystems
Company Position Title: QA Manager
Re: AutoCAD and Cloudworx - Isuues
Post by mwb » Thu Apr 13, 2017 9:13 pm
Do you realize that the version of CloudWorx that you are using is over a year old? The currently released version is 6.2, with 6.3 coming out very soon. There have been considerable fixes and architectural changes since the version that you are currently running. I would definitely consider upgrading.
Mark
safib
Full Name: Santo FB
Post by safib » Fri Apr 14, 2017 9:32 am
I tried Cloudworx 6.2. Same problems.
The Leica customer service confirm me that the "combine Pan/Zoom commands" is a CloudWorx Bug. Notting to do. I hope they will fix it on 6.3 version.
The funny think is:
I run the 5 version of the plugin (3 years old) and:
- no "combine Pan/Zoom commands" problem
- no lag on pan operations
Return to “CAD Software”
