NavVis VLX - wearable mapping
Discuss all NavVis related products here.
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Re: NavVis VLX - wearable mapping
Post by max72 »
Interesting.
Are there scan samples with no pictures/colors? In many cases I scan in poor light conditions and taking photos is impossible.
dhirota
Full Name: Dennis Hirota
Has thanked: 17 times
Been thanked: 92 times
Post by dhirota »
max72 wrote:
Fri Jun 26, 2020 1:33 pm
Interesting.
Neither the NavVis M6 nor the NavVis VLX has additional lighting that I am aware of providing. As I have suggested many times on the LSF, you need to have a Z+F sensor (either 5010X+Smart light or 5016 with the built in internal LED lighting) or to add lighting as was done in this LSF thread
https://www.laserscanningforum.com/foru ... 0&start=20
to be able to capture color scans in total darkness as shown below. We used a Z+F 5016 in total darkness to capture daylight condition colored point clouds and color image panoramas.
Dennis Hirota, PhD, PE, LPLS
GeorgSchroth
Full Name: Georg Schroth
Company Details: NavVis
Has thanked: 36 times
Been thanked: 27 times
Post by GeorgSchroth »
Interesting.
You don't necessarily have to take panos with the VLX, if you are fine with a cloud with intensity values.
I will try to get you a sample!
BTW Dennis, super interesting results on the meshing :)
max72
Post by max72 »
GeorgSchroth wrote:
Fri Jun 26, 2020 11:04 pm
Thanks,
I'd love to have a small sample.
dhirota
Post by dhirota »
Decided to try and load a NavVis VLX file on to a game platform. The largest VLX file that I currently have is from the scans from Marek Koltun of NYC.
SOHOVLX, E57=11.2GB, 444,845,248 pts.
I still need to figure out how everything works.
Kolt45
Full Name: Marek Koltun
Company Position Title: Salesguy
Post by Kolt45 »
Hi Dennis - this looks very interesting! I assume this is Unreal game engine? Are the screen shots still point cloud OR game engine converts it into mesh? Colors and quality look slightly off from what our cloud looks like.
smacl
Full Name: Shane MacLaughlin
Has thanked: 118 times
Been thanked: 134 times
Post by smacl »
dhirota wrote:
Sun Jun 28, 2020 8:46 pm
Hi Dennis,
At a glance, it looks like the pixel size is set too high in your viewer which gives the impression of a lower resolution / blurry result. You often see the same effect in potree, where the default values are setup for a wider point spacing than used in modern terrestrial scanning. The size usually scales with perspective, so points or splats nearer the viewer are larger to give the impression of continuous surfaces rather than discrete points but often needs some adjusting to suit data density.
dhirota
Post by dhirota »
smacl wrote:
Mon Jun 29, 2020 1:22 pm
Hi Dennis,
Shane
I believe you are correct about the size and positioning, but there is still too much to figure out, and not enough time.
I am disappointed with American Airlines Cargo (that is saying it gracefully) since they have been sitting on my NavVis VLX since June 19 when it was picked up in Munich, DE. If anyone is shipping anything from MUC to FRA, I suggest not using AACargo. It still has not left MUC yet.
landmeterbeuckx
Full Name: Lieven Beuckx
Has thanked: 44 times
Been thanked: 117 times
Post by landmeterbeuckx »
dhirota wrote:
Mon Jun 29, 2020 7:22 pm
Hi Dennis,
Shane
That's bloody frustrating Dennis. You could be playing around with it when delicered on time.
LSBbvba
Tel : +32477753126
www.lsbbvba.be
dhirota
Post by dhirota »
Lieven
It did leave MUC yesterday, and is stuck in FRA until Wednesday, July 1 leaving for DFW. It will arrive in HNL, July 2 at 2:21P HST if I am lucky.
Return to “NavVis”
