Paracosm PX-80 Handheld Reality Capture System
- Full Name: Gannon Wilder
- Company Details: Paracosm
- Company Position Title: Paracosm
Re: Paracosm PX-80 Handheld Reality Capture System
Hi guys,
You can download sample data here: https://drive.google.com/open?id=0B9zI8 ... 0tlTTcwMVE
It's an E57 format, so you can open it in pretty much any point cloud viewer (eg. Recap, CloudCompare).
EDIT: A couple other details about this scan:
- Scan time: 6 1/2 minutes
- Scan method: Walk a circle through the floor plan
- File size: 1.3 GB
Things to note:
- Going between dark areas and bright sunlight messes with the colorization, leaving some points overexposed (white).
- File size: 1.3 GB
Things to note:
- Full Name: Ioannis Papas
- Company Position Title: CEO
- Country: EU
- Skype Name: -
- Has thanked: 99 times
- Been thanked: 62 times
Any news from Paracosm when it will be availiable ?
Any tests again Geoslam ?
- Full Name: Sean Israelson
- Company Details: PA Spatial Solutions Inc
- Company Position Title: Field Sales Specialist
Available in Canada now from PA Spatial Solutions Inc. ([email protected])
- MarkJLane
- Full Name: Mark Lane
- Company Details: Faro Technologies
- Company Position Title: ANZ Account Manager
- Has thanked: 25 times
- Been thanked: 43 times
Impressive stats on this scanner...might anyone know if the output is compatible with Edgewise?
- Full Name: Thad Wester
It wouldnt be i dont think. Edgewise needs the scanner position for its algo
- Full Name: Neerav Mehta
- Company Details: Indoor Intelligence
- Company Position Title: CTO
- Been thanked: 6 times
That's correct. Edgewise relies on scanner positions. But Pointsense or Scan To BIM (https://scantobim.xyz) will work.
- LPaulCook
- Full Name: L Paul Cook
- Has thanked: 47 times
- Been thanked: 44 times
Accuracy stated is .16' to 1.64' after running a 10 minute loop.
What type of project would this be useful?
L. Paul Cook, PLS
www.LPC3D.com
www.LPC3D.com
- MarkJLane
Thought that might be the case.neeravbm wrote: ↑Mon Jul 23, 2018 5:55 pm That's correct. Edgewise relies on scanner positions. But Pointsense or Scan To BIM (https://scantobim.xyz) will work.
I noticed there is a fair bit of drift on one of their examples - https://s3.amazonaws.com/website.paraco ... ml#?scan=2
If you look in elevation the floor has a dramatic bend to it. Can this be resolved with target control?
In general, SLAM-based systems, which PX-80 is, don't use specific targets. They extract features from the environment around them. As the unit moves, the features move and the system tries to calculate the new position based on the movement in features as well as its internal IMU. If you add targets, they will contribute a few more features that the system tracks. But the number of features the targets contribute will be much smaller than the number of features that PX-80 will extract from rest of the environment. Hence the contribution of the targets to alignment will be much smaller than when they are used traditionally with a terrestrial laser scanner.
I think a better option might be to scan small areas using targets and then stitch them together manually. SLAM systems generally implement loop closure. Which means that when you come back to the starting position, it recognizes that and it optimizes your whole path based on the constraint that first position = current(last) position. A lot of drift gets eliminated when loop closure optimization happens. Smaller the loop or the area that is scanned, lesser the drift. So if you use targets while scanning overlapping small areas, you'll get multiple point clouds, each of them containing targets. You should be able to register these point clouds together using the targets in the registration software of your choice. This way you are getting small point clouds with very little drift and then registering all of them together just using targets at the end.
My suggestion above is based on my understanding of how SLAM systems work. It's possible that being customized for surveying industry, PX-80 has some more features for target-based alignment which I am not aware of. Gannon should be able to correct me if that's the case.
- MarkJLane
Thanks for your insights Neerav, it seems like it's more about technique when it comes to mobile scanning and reducing drift.
