Joon
Full Name: Sung Joon Ahn
Company Details: CurvSurf
Country: Republic of Korea
Been thanked: 12 times
Post by Joon »
Finding Planes in depthMap - Apple iPad Pro LiDAR
youtu.be/8ixtwnfsuzA
CurvSurf FindSurface extracts object planes through the segmentation and plane fitting to the max 3,072 points sampled from the max 256x192 depthMap points.
The max 256x192 depthMap points are generated at 60 Hz by interpolating the max 576 (3x3x8x8) laser dot points (i.e., original sensor data) together with the RGB-image.
We prefer the original sensor data of max 576 points to the sampled points from the max 256x192 depthMap points.
The access API to the original sensor data of max 576 points is not available/released yet, 20 July, 2020.
Tools used:
- Apple ARKit 4
- Apple Metal API
- CurvSurf FindSurface.
Joon
Post by Joon »
Real Time Object Recognition in depthMap - Apple iPad Pro LiDAR
youtu.be/o_D4_Azq5cs
CurvSurf FindSurface determines the shapes, sizes, positions and rotations of object surfaces by using:
- Curvature analysis: determines the shape type and the initial surface parameter values.
- Orthogonal distance fitting: refines the surface parameter values.
- Region growing: gathers the inlier candidate points.
The max 1,536 points are sampled randomly from the max 256x192 depthMap points with the reduction ratio of 1/32.
The access API to the original sensor data of max 576 points is not available/released yet: 23 July, 2020.
Tools used:
- Apple ARKit 4
- Apple Metal API
Joon
Post by Joon »
As-Built Object Geometry from Point Cloud - Apple iPad Pro LiDAR
Max 192 points are randomly sampled from the max 256x192 depthMap points of 60 Hz frame rate.
If the camera motion between two (start and end) frames oversteps the parallel motion threshold of 5 cm or the optical axis change threshold of 5 deg, then the max 192 points of the last frame are appended to the point cloud.
The object geometries are for creating a lot of contents, e.g., 3-D CAD information, game environments, work instructions, advertisements, navigation map, etc.
The ultra wide angle camera helps ease the problem of large area motion tracking.
With smart glasses, the user experience will be more immersive and two hands be free.
youtu.be/7OFsXU2JfpI
Joon
Post by Joon »
As-Built Torus Geometry from Point Cloud - Apple iPad Pro LiDAR
Lee JaeHyo (이재효, 0121-1110=110101)
http://leejaehyo.com
http://www.sungkokmuseum.org
http://www.sungkokmuseum.org/main/exhib ... re-garden/
youtu.be/4TNjcN7MLvw
Joon
Post by Joon »
3-D Measurement of Tree Branches II - Apple iPad Pro LiDAR
A measuring app will be recording DBH (diameter at breast height) of trees together with GPS coordinates, device direction, calendar day and time, tree type, snapshot, etc.
Compared to the measurement of the same tree 17 months ago (https://youtu.be/h9s8_lt1I64), ARKit 4 with LiDAR shows improvements in point accuracy, motion tracking, and work efficiency.
Tools used today Aug. 2020:
- Apple iPad Pro LiDAR (A2228) 2020
- Apple ARKit 4
- Apple Metal API
Tools used 17 months ago:
- Apple iPad Pro (A1980) 2018
- Apple ARKit 2.0
- Apple Metal API
youtu.be/_jwZ2EjzwhE
Joon
Post by Joon »
Looking into depthMap II - Apple iPad Pro LiDAR
Compared with:
Looking into depthMap - Apple iPad Pro LiDAR
about 2 months ago.
Since iOS & iPadOS 14 Beta 5, Apple has improved the quality of ARDepthData with the provisional option of so-called 'smoothedSceneDepth'.
The improvements we have observed:
- The depthMap points are more accurate but linearized
- The RMS errors of surface fitting are smaller (decreased from 2~5 mm to 1~3 mm)
- Object steps (edges) with small offset are visible
- Edges of object surface are more clear
- Planar object surfaces are more flat
- The number of noisy points in shadow boundaries are reduced
- The number of points with 'medium' or 'high' confidence threshold is increased (The number 49,152 points with 'low' confidence threshold is the max number of the depthMap points).
- The number of points with the current (beta 5, 6) 'high' confidence threshold is about the same with that of the old (beta 4) 'medium' confidence threshold.
youtu.be/ncSkQ84iDBM
youtu.be/h3PBy0psayY
Joon
Post by Joon »
In 2-D or 3-D space, the scanning is the seeing.
The 2-D scanning's result is photos and the 3-D scanning's result is point clouds.
Understanding the geometric contents of them is the same: shape, size, position & rotation of objects in 2-D/3-D space.
Why FindSurface 2020 KICT Smart construction seminar CurvSurf Dr. SJ Ahn.png
Ground breaking theory and practice of 3-D data processing and applications.
youtu.be/H1ZY1bOw0kU
Return to “Modeling Software”
