Hello
Did anybody try to scan with LEICA HDS6000 upside down ?
My goal here would be to perform scans of ground and underground area.
Is there a risk to damage HDS6000 ?
Do you know mount systems adapted to these needs ?
Olivier
scanning with HDS6000 upside down
- Full Name: olivier boissard
- Company Details: GGC
- Company Position Title: laserscanning surveyor
- Country: France
- csiebern
- Full Name: Chris Siebern
- Company Details: HNTB
- Company Position Title: Senior Technologist
- Skype Name: csiebern
Re: scanning with HDS6000 upside down
I've seen it done with Faro LS Scanners, but not the Leica. If I remember correctly, there are some issues with the bearings in the horizontal motion. The LS uses mechanical bearings while the Leica/Z+F are a ceramic bearing. The issue is how the dead load of the scanner is distributed when inverted. Can the bearings carry a tensile load when the scanner is inverted.
Do not attempt with the standard tribrach issued with the Leica scanner. It can not bear the weight of a 6000 when inverted.
- Full Name: Thorsten Burghart
- Company Details: Zoller+Froehlich GmbH
- Company Position Title: Product Manager
Hi Olivier,
It is possible to scan upside down with the Z+F IMAGER 5006(i) or the HDS 6000.
You should use the special uside down plate for such an aplication.
Don´t use the normal tribrach.
Z+F has also a special upside down tripod. (see pictures below)
With this tripod it is possible to make scans about 3m undergroud.
- csiebern
Is the upside down plate available for purchase from Z+F or is a drawing/specification that must be fabricated by a 3rd party?
- Has thanked: 9 times
- Been thanked: 20 times
Hi Olivier,
We have been using this for a while, nice piece of kit.
http://www.coastway.net/laser-scanning-page49689.html
Chris.
Chris.
- Country: France
Thanks everybody for these replies.
This system looks great.
Have you an idea of price (approx.) ?
Olivier
Olivier
Hi Chris,
The upside down plate is available to purchase from Z+F.
Regards
Thorsten
Regards
Thorsten
- Full Name: Jared Benjamin
- Company Details: Glasgow School of Art
- Company Position Title: Production Manager
Hi christopherbyrne18
Real long shot as I know this post was 9 years ago but do you have info on that HDS6000 upside down kit from a 3rd party you mention in this thread?
I am using a Z+F 5010C which has the same connection points.
I see your link has expired - no wonder after 9 years!!
Please let me know.
Lee
Please let me know.
Lee
