RTC360 Check and adjust
Faro FOCUS S350, S150, S70, M70, X30, X130, X130HDR, X330, X330HDR. Leica RTC360, C10, P15, P20, P30, P40, P50, BLK360, HDS6*00, HDS7000,HDS8800, HDS8400. Riegl VZ6000, VZ4000, VZ2000, VZ1000 & VZ400i. Topcon GTL-1000, GLS2200, GLS1500. Trimble X7, SX12, SX10, TX8, TX6, S7 & S9. Z+F IMAGER 5016, 5010X, 5010C, 5006H, 5006EX & PROFILER 9012
sdhudson
Full Name: Stephen Hudson
Company Details: Malcolm Hollis
Country: England
Post by sdhudson »
I recently updated the firmware on our RTC360 and wanted to try out the new "Check & Adjust" feature.
I tried to run it outdoors with what I thought was some interesting geometry around me, but kept being told it couldn't complete.
Has anyone successfully run this tool, and if so what surrounding features do I need to have around me. I think perhaps the lack of overhead detail may have been an issue, but that limits me to only running it indoors where the max distance of any detail from the scanner will be greatly reduced.
The whole process takes around 6 minutes so I can't afford to just keep trying and trying until I get it to work!
Thanks,
LeicaUK_RC
Full Name: Phil Marsh
Company Details: Leica Geosystems part of Hexagon
Company Position Title: UK Sales Manager - Reality Capture
Skype Name: Phil.H.Marsh
Been thanked: 36 times
Re: RTC360 Check and adjust
Post by LeicaUK_RC »
Hi Stephen,
I've emailed you a few documents which will help to give a deeper understanding of the check and adjust routine on the RTC-series scanners.
I hope this helps?
Leica Geosystems
M: 07540 201383
E: [email protected]
W: www.leica-geosystems.com
sdhudson
Country: England
Post by sdhudson »
Thanks Phil.
Very useful, will give them a try!
miguel
Full Name: Michal Gula
Company Details: SANWU
Country: Slovakia
Post by miguel »
8142 user_id=12246]
Hi Stephen,
I hope this helps?
Hi, could you be so kind and send those documents to me as well? Thanks in forward. [quote=LeicaUK_RTC post_id=88657 time=160024
virtuoso
Full Name: Ant
Company Details: Mck
Company Position Title: BIM engineer
Country: Cro
Post by virtuoso »
LeicaUK_RTC wrote: Wed Sep 16, 2020 10:22 am Hi Stephen,
I hope this helps?
Hello. Also recently updated our rtc 360 and would like to see those documents if you don't mind sharing on email?
cpw006
Full Name: Chris Widmer
Company Details: LAS
Company Position Title: 3D Scanning Manager
Has thanked: 3 times
Been thanked: 5 times
Post by cpw006 »
I too tried the check and adjust in multiple different locations and received the same message.
Matt77M
Full Name: Matthew Miles
Company Details: LGA
Post by Matt77M »
I hope this helps?
I could do with a copy of these as well if possible Phil.
Justin Hill
Full Name: Justin Hill
Company Details: Lloyd and Hill Inc
Post by Justin Hill »
Yes, me too please. Unless its just the Check and Adjust User Manual.
Andrew Chambers
Full Name: Andrew Chambers
Company Details: Laser scanning
Company Position Title: Digital Engineer
Post by Andrew Chambers »
LeicaUK_RC wrote: Wed Sep 16, 2020 10:22 am Hi Stephen,
I hope this helps?
Hi Phil could you forward on a copy of these documents to me also. Much appreciated.
mlarson
Full Name: Mike Larson
Company Details: ___________
Post by mlarson »
Could I also get a copy of these documents? - thanks!
