New 3D scanner by Effortless 3D
Discuss all effortless3D related products here.
Post by Jason Warren » Tue Aug 29, 2017 1:03 pm
#ThePowerofLSF
3DForensics
Full Name: Eugene Liscio
Skype Name: eliscio
Re: New 3D scanner by Effortless 3D
Post by 3DForensics » Tue Aug 29, 2017 1:44 pm
Very cool! I find it interesting that we now have at least 3 scanners that are in this same low-cost, low-accuracy range. Can anyone tell me if 30mm in a single scan is reasonable for most AEC projects? Where else would a scanner like this be useful for you?
What about a low cost Surphaser? Higher accuracy with clean data...just saying.
Eugene
Oatfedgoat
Full Name: Matthew McCarter
Company Details: Costain
Country: England
Post by Oatfedgoat » Tue Aug 29, 2017 4:01 pm
I guess like most scanning choices, it depends on the project.
In addition to the project, the stage of the project is probably the most important factor in deciding acceptable accuracy.
For detail design or fabrication, very unlikely that 30mm would be OK.
For feasibility 30mm would be way more than is needed - The question comes though of smart procurement of scanning at early stages with a forethought of detail design and beyond later on.
Even if the data has been captured in advance at a decent accuracy, does not necessarily mean that people working on the project at different stages later on will even be aware that the data exists.
It's all about Better Information Management. (totally stolen from Dr. Anne Kemp from many years ago!)
Formula1982
I have made 100> posts
Full Name: Stephen Ferrari
Post by Formula1982 » Tue Aug 29, 2017 5:15 pm
I'm very interested to see what sort of projects people use these types of scanners for. This and the BLK360, LasIris.
For the majority of work we see, 1mm-5mm is the typical range of accuracies requested. Maybe +/-10mm for building surveys.
So 30mm accuracy which is typical for the new breed of low cost scanners appears a bit loose for typical uses, but there must be a demand for these systems of they won't be getting made. Looking forward to seeing what they end up doing!
Post by Jason Warren » Tue Aug 29, 2017 8:37 pm
I like the 360 x 360 field of view and the minimum scanning distance of 100mm.
#ThePowerofLSF
tbwester
Full Name: Thad Wester
Company Details: WeWork
Post by tbwester » Tue Aug 29, 2017 8:57 pm
IMO the BLK is not in the same breath as the other scanners. Its better.
Interesting scanner, be cool if it had a little slick registration software.
Eugene
It depends. Its better than nothing (even if your 1 foot off you still see piping, ducts, etc...). But for MOST applications you need to be close to reality if your going to use the data. We are still researching the boundaries ourselves.
jedfrechette
Full Name: Jed Frechette
Company Details: Lidar Guys
Company Position Title: Lidar Supervisor
Post by jedfrechette » Wed Aug 30, 2017 5:51 am
or they won't be getting made.
I'm almost certain that all of the product images showing this scanner are CG bullshots, so I'm not sure we can take for granted that it is getting made quite yet. ;)
It seems like the trick with any of these low res scanner will be accurately registering the data together. It's one thing to have data with a precision of only 3 cm, but if that low precision also makes it difficult to accurately align multiple scans and cover any significant area then that is a much bigger problem. Of course, you can mitigate the low scanner accuracy by adding more sensors or smarter software, but that won't necessarily be cheap.
blazaj
Full Name: Jiri Blazek
Company Details: Blazek Win Precision Systems
Company Position Title: 3D documentation
Country: Czech
Skype Name: blazaj
Post by blazaj » Wed Aug 30, 2017 7:23 am
With the angular resolution 0.25° at max distance range 20m you'll get a grid with points spaced at 87mm. That would mean quite a lot of setups with a tripod based system to sufficiently cover anything larger than a standard room.
dhirota
Full Name: Dennis Hirota
Post by dhirota » Wed Aug 30, 2017 7:31 am
I have their spec sheet which is non-specific on wifi and HDR, which can be and are current problems with other sensor systems.
Dennis Hirota, PhD, PE, LPLS
dennishirota@gmail.com
ChrisHarris
Full Name: Chris Harris
Company Details: KOREC
Company Position Title: Strategic Account Manager
Post by ChrisHarris » Wed Aug 30, 2017 1:58 pm
Agreed! really interesting and could be very useful for projects with tight spaces
Return to “effortless3D”
