.BLK Files all less than 1kb using data manager
zyborgmonkey
Full Name: Nathan
Company Details: Cub2
Post by zyborgmonkey »
I don't know what's going on with this again, it seems like every time I use the BLK360 some issue comes up!
So this time around I've picked up 60 scans and have come to download them via the data manager and usb WiFi dongle. Have done it previously with no issues.
This time however I left it running and for what ever reason once it hit 33 data manager crashes. Also on checking the files downloaded so far they seem to all be less than 1kb in Windows this time even though they took the standard time to transfer.
No HDR images. A few Hi Res the rest Med
zyborgmonkey
Full Name: Nathan
Re: .BLK Files all less than 1kb using data manager Solution
So I think I've found the reason although doesn't explain why each file was so small.
I've been transferring directly to my SSD which only had about 9GB left on it so presumably the reason for the crash was that it ran out of space.
Solution was to copy to a Folder on the desktop instead which seems to work ok so far
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 190 times
Been thanked: 45 times
Post by gsisman »
zyborgmonkey wrote: Tue Jun 05, 2018 10:47 pm So I think I've found the reason although doesn't explain why each file was so small.
I suppose you have the newest data manager v1.5 just came out in August. We had the issue earlier when using a USB Wifi mini plug. It was our network not allowing the download from an external network (seeing the BLK360 internal network as a rogue network). We're a county government and the Hardwire network was on at the same time we were connecting to the BLK
