RTC 360 Images
Faro FOCUS S350, S150, S70, M70, X30, X130, X130HDR, X330, X330HDR. Leica RTC360, C10, P15, P20, P30, P40, P50, BLK360, HDS6*00, HDS7000,HDS8800, HDS8400. Riegl VZ6000, VZ4000, VZ2000, VZ1000 & VZ400i. Topcon GTL-1000, GLS2200, GLS1500. Trimble X7, SX12, SX10, TX8, TX6, S7 & S9. Z+F IMAGER 5016, 5010X, 5010C, 5006H, 5006EX & PROFILER 9012
sdhudson
Full Name: Stephen Hudson
Company Details: Malcolm Hollis
Country: England
RTC 360 Images
Post by sdhudson »
I appreciate this is something I can test for myself, but to save wasting time, can anyone advise where I should stand when using an RTC360 to capture images, so that I don't appear in all of them!
Which camera lens(es) are actually being used to take the images?
If I stand perpendicular to the line of site of the scanner mirror, is this a safe blind spot to be?
Thanks!
stevenramsey
Full Name: Steven Ramsey
Company Details: 4DMax
Skype Name: steven.ramsey
Has thanked: 28 times
Been thanked: 46 times
Re: RTC 360 Images
Post by stevenramsey »
they are the thre down the front. the 4 on the corners (domed) are the viz
Rule of thumb if your perpendicular to the screen you wont be seen.
Steven Ramsey
Home [email protected]
Work [email protected]
Mobile +44 7766 310 915
Scott
Full Name: Scott Page
Has thanked: 122 times
Been thanked: 48 times
Re: RTC 360 Images
Post by Scott »
Zoot allures*, blimey!--I had no idea that RTC360's 'quirks' began with this basic issue! Send it back to the kitchen...good Lord! :lol:
*Frank Zappa
sdhudson
Country: England
Re: RTC 360 Images
Post by sdhudson »
That’s great thanks Steven!
Has thanked: 299 times
Been thanked: 61 times
Re: RTC 360 Images
Post by gsisman »
sdhudson wrote: Fri Jul 02, 2021 6:22 pm That’s great thanks Steven!
It moves so fast, you may as well sit on the ground underneath it. Don't even try merging scans as you go if you are using Cyclone field 360. Work in a group and then Download them in a bunch at a time to see your progress.
JNally
Full Name: Joe Nally
Company Details: EPS
Re: RTC 360 Images
Post by JNally »
stay in line with the screen on the scanner. And if you cant see the center of the scanner it can't see you!
