DPI 8 Handheld Scanner
Discuss all DotProduct related issues here.
CJGabel
Full Name: CJ Gabel
Company Details: VM Systems Inc.
Post by CJGabel » Thu May 18, 2017 1:21 pm
It has been awhile since I have been active here but you guys were so helpful in the past I thought I would give it a try with our new product. I am a CAD/Scanning guy for a sheet metal contractor out of Toledo, Ohio. I have a new job that is way out of my wheelhouse. In this job I am scanning "clover" shaped windows to get CAD files to a window manufacturer. We have about 80 windows to do and they are four stories up. In the past i have worked with the Trimble TX5 but I thought this would not work up in a lift so we purchased a DPI 8.
The stone around the windows is fairly reflective and in the daytime I am not finding any way to make this work. Has anyone had any experience working with this? I read before we purchased that the handheld does not perform well in direct sunlight, but even in shady conditions of a courtyard our results were not very good. I am starting to think my only option is to work 3rd shift overnight but my contact want to see if an "umbrella" type device would work. Any thoughts or suggestions would be greatly appreciated.
Thanks,
CJ Gabel
cadmium
I have made 70-80 posts
Full Name: Jason Bayer
Re: DPI 8 Handheld Scanner
Post by cadmium » Thu May 18, 2017 1:47 pm
Are you using targets or april tags when using the handheld?
Does it lose tracking, or does the scan just come out warped when its done?
I will choose to use the TX5 over the DPI-8 whenever I can.
Can you anchor the TX5 scanner to a column clamp or something?
steves01x
Full Name: Steve Smith
Company Details: IIC
Country: Scotland
Post by steves01x » Thu May 18, 2017 2:22 pm
You could try photogrammetry - a left & right pair. If you went medium format you could get a loads of the windows in each pair of photos? And use the total station for control for all the targets in each photo. Or even use a UAV?
More info on photogrammetry:
http://www.tsa-uk.org.uk/downloads/
https://historicengland.org.uk/images-b ... -heritage/
CJGabel
Full Name: CJ Gabel
Post by CJGabel » Thu May 18, 2017 3:38 pm
Cadmium,
Yes I am using April Tags. After I updated the software recently the tracking has become much better. With the reflective stone I am generally just getting a "blank" space where it appears it is not even seeing the stone. I have done this at night and had much better results. I have found much better results with the TX5 and when I spoke to a Trimble field guy he said he has used the TX5 in lifts before, but being 4 stories up i am swaying easily 5-6 inches, so to me this is way to much. I did not think about possibly mounting the TX5, I will look into that.
Steves01x,
I have not heard much about photogrammetry and when I get a chance I will look through those links.
Thanks for the input gentleman.
WWilford
Full Name: Warren Wilford
Company Position Title: owner
Post by WWilford » Fri May 19, 2017 11:17 am
I made this rig for scanning out of windows and have had good success with it.
cahern3d
Full Name: Chris Ahern
Company Details: DotProduct
Company Position Title: Marketing Manager
Post by cahern3d » Wed Jun 28, 2017 8:29 pm
Hi CM,
Glad to hear you are getting better results with updated software, and that you're utilizing AprilTags for your scanning. For the shiny stone, the best suggestion is to avoid sunlight as you have, and approach from different distances and angles. This will typically do the trick for almost any surface that is not fully mirrored/polished/reflective/transparent, but may require some more patience while scanning. I've never seen any type of stone that can't be captured with the DPI-8/X. Please feel free to contact us directly with any further questions: https://www.dotproduct3d.com/contact-support.html
Best,
Chris
Return to “DotProduct”
