Hi All
I am working with geoslam in cyclone, but this is a timeconsuming process for me, because it has some issues with importing the normals into cyclone.
Currently the process is to calculate the normals in CloudCompare and import that into cyclone, where the normals gets computed.
I havent had any luck, woth just exporting the normals from geoslam desktop:
Does any of you guys have any experience in this field and maybe a more efficient way?
Geoslam into cyclone
- Full Name: Martin Graner
- Has thanked: 160 times
- Been thanked: 175 times
Re: Geoslam into cyclone
Did you try to use GeoSLAM Hub to calculate the normals?
This should get good results because they can use the trajectory of the scan to compute them more stable.
- Full Name: Mark Reid
- Company Details: GeoSLAM
- Company Position Title: Chief Operating Officer
- Skype Name: mark.reid21
You can export an e57 with normals directly from GeoSLAM Hub and it will work well inside Cyclone
- Full Name: Chris Widmer
- Company Details: KCI
- Company Position Title: 3D Scanning Manager
- Has thanked: 3 times
- Been thanked: 8 times
You can import e57 into Cyclone and then select the imported files, right click and select generate\compute normals.
- Full Name: Malte Holm
- Company Details: TLS
- Country: Norway
Could anyone of you guys take a screenshot of your settings in Geoslam desktop and Cyclone, cause i tried it, but Cyclone wouldent accept the normals?
- stevenramsey
- Full Name: Steven Ramsey
- Company Details: 4DMax
- Skype Name: steven.ramsey
- Has thanked: 30 times
- Been thanked: 72 times
just turn off the "import normals on import" option in the pointcloud section of the preferences
- Peyman Bashiri
- Full Name: Peyman Bashiri
- Skype Name: pbashiri2003
- Has thanked: 56 times
- Been thanked: 40 times
Wow Steven, Just one sentence to fix it all. I wish I`d knew it before. I spent about 3 days waiting cyclone to import a Zebd scans with Normals without any luck.stevenramsey wrote: ↑Fri May 11, 2018 1:31 pm just turn off the "import normals on import" option in the pointcloud section of the preferences
Thank Steven
