compress PTX file
- phillhend
- I have made 60-70 posts
- Full Name: Phillip Hendrickson
- Company Details: PennDot Photogrammetry and Surveys
- Company Position Title: Terrestrial LiDaR Technician
compress PTX file
I have Polyworks ver. 12 and with it only the IMinspect and IMview licenses. Using just IMinspect can I compress/ unify and reduce the amount of points in the scanworld?
- Phill
- Full Name: Phillip Nixon
- Company Details: SKM
- Has thanked: 7 times
- Been thanked: 45 times
Re: compress PTX file
Phill
There is a decimater I wrote for ptx files here.
http://www.laserscanningforum.com/forum ... &hilit=ptx
Not sure if that's what your looking for
Phill
Phill
- nickherath
- Full Name: Nick Herath
- Company Details: Veris
Right click on the dataset/s, Edit -> Subsample
You can apply the subsample to either the objects in the feature tree or to selected points and decimate either by uniform spacing or by curvature.
Remember that once you have the PTX in ImInspect it is no longer a PTX scan (ie. gridded data) but if you had your import settings for max angle and max distance set correctly then you will have point normals instead of just dumb xyz points.
- Full Name: SAttaya
- Company Details: Sev1Tech
- Has thanked: 127 times
- Been thanked: 17 times
How do you know what the "correct settings" are for max angle and max distance?nickherath wrote: Remember that once you have the PTX in ImInspect it is no longer a PTX scan (ie. gridded data) but if you had your import settings for max angle and max distance set correctly then you will have point normals instead of just dumb xyz points.
Are there defaults, like 200m (if max range on scanner is 150M) and max angle of 90, 180, 360?
