Hi everyone.
How to change origin coordinate system in Z+F LaserControl?
I want to change origin coordinate point cloud data to X = E 100000mm Y= N 1000000 Z = 13.3m.
Could anyone help me please?
Thank you so much!
Change origin coordinate system
- Full Name: Thanh Cao
- Company Details: StarGlobal3D
- Company Position Title: StarGlobal3D
- Country: Vietnam
- I have made 60-70 posts
- Full Name: Christoph Held
- Company Details: Zoller+Froehlich GmbH
- Company Position Title: Z+F Team
Re: Change origin coordinate system
Dear Thanh
LaserControl allows you to create, manage and switch between multiple coordinate systems by using the ‘manage coordinate systems’ tool. For Annotations, Tachy-System and GPS (UTM) the coordinate systems are already given. If it is necessary to specify an alternative co-ordinate system to place the project into, a new coordinate system needs to be added. This can be achieved by clicking the ‘Add…’ function on the right.
With the option “Set origin position (XY plane)” you can select your origin point and set the desired X and Y coordinates.
The height of the origin can then be set afterwards by using the option “Set origin height (Z)”.
I hope this information is of help to you. Please do not hesitate to contact support(at)zf-laser.com, should you have any further questions.
Best regards,
Chris
Best regards,
Chris
