Help! Comparison guidelines
For comparison of laser scanning products
joserizal
Full Name: ross ryan p. matic
Company Details: Maynilad water
Company Position Title: Head
Country: Philippines
Post by joserizal » Tue Mar 14, 2017 2:53 am
Hi!
We are planning to acquire terrestrial scanner in our company; major use will be in asset trailing and also at in surveying works.
For now this are the equipment we have determined for comparison:
• Lieca P40
• Faro M70
• Trimble Tx8
Any suggestions what critical checklist should we consider for comparison?
steves01x
I have made 70-80 posts
Full Name: Steve Smith
Company Details: IIC
Country: Scotland
Re: Help! Comparison guidelines
Post by steves01x » Tue Mar 14, 2017 7:56 am
The work flow - P40 to Cyclone is rather good and smooth, you can also set up over known points with it.
Faro to Cyclone (usually via Scene) work ish but isnt as smooth. Not used the other one you mention.
Also check the quality of imagery each takes and the options for alternative camera units.
Can you hire each one for 2 days and scan your office (or house) inside and out, process the data in each brands own software and see how it goes?
NOVAMECH
Full Name: Nick Bush
Company Details: NOVAMECH
Country: New Zealand
Skype Name: novamech5
Post by NOVAMECH » Tue Mar 14, 2017 8:01 am
Forget them all and buy a ZF5016
You will find Support and Back Up - the best in the industry - I have found this to be personally true. After I experienced other support systems.
This is the most importent asspect of buying a scanner - the help and support you receive. Especially, if your team is new to scanning.
1.SOFTWARE - The ZF Range of scanners comes with FREE Scout WorkFlow "REGISTRATION" Software. Allowing, completion of registration on site prior to leaving the work environment,
2. BEST in class - HDR on Board Camera
3. Smart Light Technology - now built into scanner allowing HDR image capture in No and low light conditions. A real Asset that others do not offer.
4. Again - Scanner and Software Support - I have found to be - almost instantaneous or over night here in New Zealand. I have alway been able to have an issue resolved within a few hours or at the longest 24 hours.
Buy the way - if you are laughing at my new Avatar image - this is after scanning for 14 hours in the New Zealand Sun - working with Jed from Lidar Guys and on the Movie Film Set - "A Wrinkle in Time" - Filmed - South Island, New Zealand
http://www.zf-laser.com/Z-F-IMAGER-R-50 ... .html?&L=1
Additionally - I would look at a Robust Aluminum Tripod - with central leg stays. These are light and easily packed down while moving from position to position. The central leg stays are a must - when you are placing 100k on your tripod. These also give the advantage of locking the legs while moving the tripod.
Jamesrye
Full Name: James Rye
Post by Jamesrye » Tue Mar 14, 2017 10:26 am
Range (test this for yourself as the quoted ranges can be misleading)
Accuracy
Quality + Speed of internal camera
Speed of laser scan data capture
Operating temp range
data storage
battery life
Weight of scanner
Price!!
I've used the P40 quite a bit, the data capture is extremely quick. The quality of the data is also very high and you can pick out detail, it works well scanning wet surfaces, where our C10 wouldn't collect data. It also seems to consume less battery power than the C10. I rarely use the internal camera as it's very slow. In my experience, the Leica units are robust and reliable, though they are heavy and cumbersome. One thing to be prepared for is the volume of data that the new units collect, data handling can be a challenge on larger projects.
I really like the Cyclone software, it's perfect for registration. Additional licenses are very expensive though (in my opinion), so its worth checking out what the other vendors software offers.
steves01x
Country: Scotland
Post by steves01x » Tue Mar 14, 2017 1:54 pm
battery life
Weight of scanner
You soon get use to the P40 weight, but rather a heavy scanner than a light one when working out doors (unless its a fair old hike to site!)
P40 batteries are good, you will get a days work (8 hours) from 4, we have 6 and have not ran out of power on a long day with constant scanning / not powering off. Hot swapping the batteries between scanning is a huge time saver - something you cannot do with the Faro which is pretty annoying as you need to power off/on then start working again!
I have never used the ZF5016 (or any of that brand) but they also do look like excellent scanners as does the Reigl range!
Return to “Product Comparison”
