"invisible points" e57 export
- Full Name: Stephen Koller
- Company Details: Finelli Iron Works
- Company Position Title: Design Engineer
Part of my workflow is to export .e57 from Cyclone register360. If I "clean" the point cloud using register360 then export it, when I pull it into CC, visually the cloud is trimmed. The properties of the cloud still state the full number of points for the un trimmed cloud. the file size also confirms this. Sometimes running the segmentation tool and selecting all the visible points will do the trick...but that's only about 20 percent of the time.
Is there a way to show these invisible points or to just delete them from the file somehow. I have tried to solve this through cyclone, but there is no solution there. Thank you for your help
- Leandre Robitaille
- Company Details: Cima+
- Has thanked: 61 times
- Been thanked: 246 times
Re: "invisible points" e57 export
Im not certain I understand your invisible point issue. Does it look like the survey was passed threw a paper shredder? This issue is often caused by large coordinate pointcloud. When importing in cloudcompare accept the prompt message to do a translation to the pointcloud. Dont worry when you will re export from cloudcompare they will keep their world coordinates and not the translated one.
Thank you for your response. Sorry if my explanation is vague. Let me try to simplify it...
Full point cloud = 40 million points
I trim point cloud in register 360 to what I need and it should be around 8 million points
I export it from register360 as e57 - file size reflects 40 million points
wen i open e57 in CC - visually the point cloud is trimmed (8 million visual points), but the properties in CC state 40 million points
Where are the 32 million points that CC is recognizing and not displaying .... and how do I get rid of these "invisible points"
I hope that clears it up a little bit
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 767 times
- Been thanked: 148 times
Did you export with the Export cleaned pts to E57 unchecked?stevek wrote: ↑Thu Dec 17, 2020 3:02 pm Thank you for your response. Sorry if my explanation is vague. Let me try to simplify it...
https://www.screencast.com/t/EK8gPEzVki
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Sounds like a relatively small point cloud. If you want to send the E57 through to me I can run it through SCC here to see if there is any way to differentiate the active and inactive points. I know that LAS point clouds can include classification b but am not sure about E57. Could be they all have a fixed colour or intensity and can be filtered out that way.stevek wrote: ↑Thu Dec 17, 2020 3:02 pm Thank you for your response. Sorry if my explanation is vague. Let me try to simplify it...
- danielgm
- Country: France
- Has thanked: 11 times
- Been thanked: 34 times
A user has reported a similar file (also generated with a Leica software tool). All the spurious points were located at (0, 0, 0) - millions of them!
You can create a small sphere at this position (with the File > Primitive factory) so as to easily spot the position. The use the scissors tool to remove then.
So that was just an example to illustrate what is happening. I would like to send to you, but the file is approx (7 clouds @ 40million points per cloud) 6.5GB. what would be the best way to get it to you?smacl wrote: ↑Sun Dec 20, 2020 12:46 pmSounds like a relatively small point cloud. If you want to send the E57 through to me I can run it through SCC here to see if there is any way to differentiate the active and inactive points. I know that LAS point clouds can include classification b but am not sure about E57. Could be they all have a fixed colour or intensity and can be filtered out that way.stevek wrote: ↑Thu Dec 17, 2020 3:02 pm Thank you for your response. Sorry if my explanation is vague. Let me try to simplify it...
Thank you for your reply. So I followed these instructions with no success. I tried the SOC tool and it will freeze every time if there are "invisible points" in the file. I would like to send to you, but the file is approx (7 clouds @ 40million points per cloud) 6.5GB. what would be the best way to get it to you? You might be able to figure it out much easier than I can.danielgm wrote: ↑Sun Dec 20, 2020 5:52 pm A user has reported a similar file (also generated with a Leica software tool). All the spurious points were located at (0, 0, 0) - millions of them!
"thank you for your reply. Yes I did. And the clouds come in "cleaned" visually. Hence the reference to invisible points. The point counts and the file size still reflect the uncleaned scans, but all the extra points cannot be seen.gsisman wrote: ↑Sat Dec 19, 2020 1:31 amDid you export with the Export cleaned pts to E57 unchecked?stevek wrote: ↑Thu Dec 17, 2020 3:02 pm Thank you for your response. Sorry if my explanation is vague. Let me try to simplify it...
- smacl
A big file transfer program like https://wetransfer.com/ is probably your best option. Doesn't need to be the whole thing, just any E57 file that has this issue. If you can get the whole file over, I should be able to send the reduced version back.
