Istar Workflow
Discuss all NCTech related issues here.
formbysurveys
I have made 70-80 posts
Full Name: Andy Roberts
Company Details: Formby Surveys Ltd
Skype Name: formbysurveys
Re: Istar Workflow
Post by formbysurveys » Tue Nov 17, 2015 10:05 pm
pburrows145 wrote:
Rollo wrote:Looking forward to seeing how NCtech and Leica solve the puzzle!
Someone might be working on this right now Rollo... ;)
Another fine example of the need for a LIKE button ;-)
Kind Regards
Andy
Andy Roberts
Managing Director
Formby Surveys
Andy
Andy Roberts
Formby Surveys Ltd
Majid_noori
Full Name: MAJID DOOST
Company Details: Denada Surveys
Company Position Title: Laser Scanning Manager
Re: Istar Workflow
Post by Majid_noori » Wed Nov 18, 2015 6:28 am
Hi All,
It might be a good idea to have two separate lists in Cyclone like "left foe images and right for Scans" then relate the corresponding scans to images and run the import in batch mode.
MAJID
dschultz
Full Name: Daniel S Schultz
Company Details: uGRIDD
Company Position Title: Technical Consultant
Re: Istar Workflow
Post by dschultz » Wed Nov 18, 2015 2:19 pm
Does someone have an iSTAR setup that they can share? I would love to play around a little.
Daniel Schultz
Technical Consultant at uGRIDD
(346) 708-4743
Dschultz@uGRIDD.com
www.uGRIDD.com Unlock the Power of Your Infrastructure Data
pburrows145
Full Name: Paul Burrows
Re: Istar Workflow
Post by pburrows145 » Fri Mar 04, 2016 1:55 pm
I may have seen something, and it may be awesome ;)
Put simply, the implementation should make you all very happy. Certainly made me smile! :D
NTocher
Full Name: Neil Tocher
Company Details: NCTech Ltd.
Skype Name: ntocher
Re: Istar Workflow
Post by NTocher » Fri Mar 04, 2016 10:47 pm
pburrows145 wrote:I may have seen something, and it may be awesome ;)
Thanks Paul, We are all looking forward to sharing what might have been developed. Not long now.
tmcmillin111
Full Name: Tyler Curtis
Company Details: Autodesk and Leica Trainer-Renter-Sales
Re: Istar Workflow
Post by tmcmillin111 » Tue Feb 21, 2017 3:26 pm
max72 wrote:Tested it..
It looks like you can split your E57 with cloud compare from command line:
Create a bat file . I named it: Cloudcompare split e57.bat
Inside it write the following line:
Code: Select all
for %%f in (%*) DO "C:\yourpathtocloudcompare\cloudcompare.exe" -SILENT -O %%f -C_EXPORT_FMT E57 -SAVE_CLOUDS
Change the path to your cloud compare.
-SILENT eliminates prompt boxes
-O %ff opens the files you dran and drop to the bat file
-C_EXPORT_FMT E57 selects the output format
-SAVE_CLOUDS forces to save the clouds
Now simply drag and drop your clouds to the .bat file
the file names are the processing timestamp and not the original scan name. Could it work?
Can you explain this process in more detail @max72? My .bat file looks like this:
@ECHO OFF. ECHO. ECHO
dir C:\Users\Application Engineer\Desktop\test.e57
CODE: SELECT ALL
for test.e57 in (C*) DO "C:\Program Files\cloudcompare.exe" -SILENT -O test.e57 -C_EXPORT_FMT E57 -SAVE_CLOUDS
I am no coder, and am struggling to get this to work. My test.e57 contains 3 scan that I want to save as 3 individual E57's.
-Tyler
Return to “NCTech”
