Bad Quality Istar Coloured Orthophotos in Scene
Discuss all NCTech related issues here.
jbijlstra
Full Name: Jaap Bijlstra
Company Details: Scan360
Company Position Title: Projectmanager-Engineer
Post by jbijlstra » Mon Dec 12, 2016 9:34 am
Dear Readers,
with Colourcloud V1.10, I coloured Faro Scans of a Church with iSTAR Panoramas. However when I export Orthophotos in Scene the quality of the Photos is bad. My question is: what did I do wrong in the process from colouring the Scans till exporting the orthophotos in Scene?
In colourcloud I tried the 3 options from iSTAR Equirectangular(PNG) but still I have black lines in my Faro View.
In the attachment I put one Orthophoto and the View in Faro Scene
I hope someone can solve my Problem.
Thanks,
Jaap
Rikore
Full Name: Bruce Yager
Re: Bad Quality Istar Coloured Orthophotos in Scene
Post by Rikore » Mon Dec 12, 2016 1:19 pm
Jaap,
Try running the photos through iStar's Immersive Studio first, then import them into Scene.
Badders
Full Name: Andrew Baddeley
Company Details: NCTech Ltd
Company Position Title: Technical Sales Director
Country: Scotland
Skype Name: badders
Post by Badders » Mon Dec 12, 2016 1:59 pm
How did you position iSTAR relative to the scanner head on the tripod?
jbijlstra
Post by jbijlstra » Mon Dec 12, 2016 2:19 pm
Hello Bruce,
Thank you for the reply. I generated all the Panoramo fotos in Jpeg Format. However i don't get what the NCTech Colourcloud Software generates with the JPEG File. In the Log file I only see that the .nctri File is used to Colour the Pointcloud.
Regards Jaap
jbijlstra
Post by jbijlstra » Mon Dec 12, 2016 2:22 pm
Hello Andrew,
I changed the height of my Scanner tripod around 40mm when I fixed the Istar.
Badders
Country: Scotland
Skype Name: badders
Post by Badders » Mon Dec 12, 2016 2:25 pm
jbijlstra wrote:Hello Andrew,
So did the tripod move between taking off the scanner head and attaching the iSTAR camera?
jbijlstra
Post by jbijlstra » Mon Dec 12, 2016 2:48 pm
Hello Andrew,
Thank you for the reply. It is possible that the tripod moved with exchange from scanner and Istar. But can that be the reason of the Orthophoto quality. Because in every seperate scan the colouring looks good especially when I export from for instance 8 scans in a clippingbox it happens. When I have less scans, the quality is a better. I attached another orthophoto somewhat better.
Regards Jaap
flohrd
Full Name: Daniel Flohr
Company Details: FARO
Post by flohrd » Mon Dec 12, 2016 4:47 pm
Seems like you are visualizing individual scans rather than having one unified data set.
Try to create a project point cloud with color balancing activated. Also activate the duplicate points filter.
This should remove most of the visual clutter.
jbijlstra
Post by jbijlstra » Tue Dec 13, 2016 7:57 am
Hello Daniel,
that solved the issue! Thank you a lot. In the attachment is visible how the orthophoto looks with using the project point cloud option with the filters.
Orthophoto.tif
Regards Jaap
Return to “NCTech”
