Thanks for your reply,
I had seen the creating customized Standard Tables, but the problem with some non-standard ibeams is that every single of them is different from another . I think it would be very handy to have a scale option alongside the “Resize” button in the 2D window, so the user can create a new ibeam just on the fly and if needed store it in tables.
Regards
Majid
Chris Scotton wrote:Hi Majid,
Thanks for your thoughtful assessment of EdgeWise. The clipping box is definitely a weak point--look for a completely revamped clipping box in early 2015.
On the non-standard steel issue...you can easily import a custom standard or create your own standard using our standards editor. Once the custom standard is completed, the software will best-fit structural members to the point cloud using the that standard, if you specify it. One of my support guys can walk you through how to do that if you need help.
Best,
Chris
