Structural import to Revit - no verticals
Discuss ClearEdge3D software here.
danbigs
7
Full Name: Daniel Beighle
Company Details: Self Employed
Post by danbigs »
I'm finding that when I import a group of structural elements, the vertical components do no show up.
For the record, it's not a visibility issue. The total number of imported items listed in the Edgewise import dialogue is too few by exactly the number of vertical members.
Has anyone else found/solved this issue? Thanks in advance for any guidance.
Honorary Member
Honorary Member
16
Has thanked: 45 times
Been thanked: 40 times
Re: Structural import to Revit - no verticals
Post by Matt Young »
At first I was going to say that it could be due to vertical members for a floor level getting shown on the floor below. I think Revit still does this.
But reading all of what you are saying it sounds like they are excluded from the export for some reason.
danbigs
7
Post by danbigs »
Excluded from the export seems right.
There is also some chance that they are being considered columns, and between the export and import functions, Revit is omitting them.
Kevin
I have made 80-90 posts
13
Full Name: Kevin Williams
Company Details: ClearEdge3D
Company Position Title: CTO
Post by Kevin »
Have you looked at the "Revit Valid?" column in the EdgeWise SmartSheet? Some of the type/role combinations are not supported and cannot be exported. This column will tell you whether it can be exported or not. You may need to change the role from "column" to Beam or Brace to get it to come in.
danbigs
7
Post by danbigs »
Thanks Kevin! I actually just got that info directly from other folks at clear edge as well. You are exactly right.
Good tech support all around!
Thanks again - problem solved.
Return to “ClearEdge3D”
