Hello my friends,
In this topic I would like to make discussions on the Modeling section of Trimble Realworks.
First: Do you think, which is better: Registering the clouds into a project, and deliver the clouds for the drafters, in any format they want to use in third-party softwares? I mean, the Bentley, Acad, Cloudcompare, etc. have special plugins in order to use the clouds to make deliverables. (DTM, Auto-Piping,etc.)
OR Do you think RW is good enough for Modeling stand-alone?
If yes
What are the recommendations to use the tools to come up with good results? I mean, Easypipe looks great on youtube videos, but what should we know beside this. What point density, sampling does the tool need, to make it work so smooth?
I'm looking forward to the advice, opinion, experiences
Modeling in RealWorks
- I have made 80-90 posts
- Full Name: Robert
- Company Details: Construsoft
- Company Position Title: Technical Support
- I have made 60-70 posts
- Full Name: Tony Millington
- Country: uk
Re: Modeling in RealWorks
Hi Robert
It's not just Easypipe (or RealWorks) that looks great on Youtube videos - I'd take them all (from whichever manufacturer) with a pinch of salt.
In answer to your question, it really depends on what level of complexity and how 'finished' a model you are hoping to achieve.
The modelling from pointcouds in Realworks is acceptable for basic shapes, structures etc and the pipe run modelling will handle pretty straightforward configurations.
However, bear in mind that Realworks, Cyclone and similar are primarily tools for processing and registering pointcloud data, and that is their real strength - to expect them to handle complex modelling as well is asking a lot.
If you're looking for rigorous and complete fully modelled CAD deliverables you need to look at products that will take the pointcloud data into an environment geared to producing that - so back to Bentley, Autodesk, Kubit and the like.
Hope that helps
Tony
Hope that helps
Tony
- Full Name: Robert
Hi Tony,TMillington wrote:Hi Robert
Tony
I accept your opinion. The required deliverable decides if the RW is enough or not. I used Bentley for piping before, so I should only use RW when I make cross sections for the drafter, and they only want to know a small detail of the area to make clash detection.
Do you think is it enough for this, and do you have any recommendation what are the factors that makes the easypipe etc. tools working well? Should I segment properly the cloud where I want to use the tool, density, etc.
Thank you so much.
