I have been having to export point clouds from Realworks to ReCap.
Most times, this works fine, and I am able to open the file in Autodesk ReCap with no issues. However, about once every 10 exports or so, I get a weird ghosting image in ReCap.
What I mean is: points I edited out of the point cloud file I am exporting show up in the ReCap file when I open it, and even odder, it seems to be rotated on a new axis.
For example, I had an building exterior that was just flat windows and mullion. When I exported it, the wall was there, but there was a second wall too. It was on the same center axis, but rotated. Graphically, it looked like what would happen if these two symbols were merged: | and \
Has anyone else experienced this, and if so, what can I do?
Thanks and have a great Memorial Day weekend!
Realworks to ReCap
- Full Name: John P Wolf
- Company Details: Staff
- Company Position Title: GIS Technician
- I have made 60-70 posts
- Full Name: Tony Millington
- Company Details: ISIS Rutherford Appleton Laboratory
- Company Position Title: Survey section leader
- Country: uk
Re: Realworks to ReCap
Hi John
We invariably take pointclouds from RealWorks into Recap and I haven't seen this issue occur.
However I always export the cloud as .e57 (because we also import to other software on occasions) from RW and then import that to Recap.
I've not used the direct export to Recap so can't comment on that.
Regards
Regards
- 3
- Full Name: Dmitry Kutsko
- Company Details: A-GEO LLC
- Company Position Title: Scanning engineer
- Country: Russia
Recap is a strange software. Sometimes during re-open it damages the project that was previously made in ReCap and looked good. For example, it can rotate some rooms in a project that contain a 100+ stations.
I often use direct export of gridded point clouds to ReCap and all of them look good except projects that had issues during export.
- 3
- Full Name: Dustin J sirman
- Company Details: Cam Integrated Solutions
- Company Position Title: 3D Survey Lead
- Has thanked: 4 times
- Been thanked: 5 times
yes i have had this issue come up and its completely random like you said. i will have a point cloud all registered and set to coordinates but when i export it, it will have a scan or two out of place.. this has only happened twice since i have been using it but its always when i do a export strait to recap.
- Full Name: Pavel Grée
- Company Details: XGEO
- Company Position Title: executive one
- Country: Czech Republic
- Has thanked: 5 times
Hi, I experienced similar problems with direct TRW to RCP export (100+). Solved by TRW to PTX to RCP. Takes more time, but works OK.
