I rented out a SX10 and took several scans of a building facade. I need to get the data into TRW to combine and register with other Faro Scans from the same site. I've done it before and it worked fine. This time however the scanner software was preset to local georeferencing defaults. When I open the JOB file in TRW I get this error message:
Does anybody know how to bypass it and get the scans, just scans, levelled but unregistered from a JOB file? Any help much appreciated!The file 'plzenbw.job' requires a geoid, datum grid, projection grid or other auxiliary file that cannot be found on this computer.
To rectify this problem you should copy any required files into the GeoData folder on this computer.
Please refer to the help file for further details.
Thanks,
Jiri
EDIT: Solved by local Trimble office, scale had to be set to 1.00 in the field software when scanning. Thank you!
