Dear Experts,
I need help with Trimble Realworks automatic pre-sampling of points clouds when using some modules. Modules I had problems with are Sampling Tool and Multi-Ortho projection. I have a project point cloud with 250Mpts. When I open spatial sampling module, it immediately random samples it to around 20Mpts (more than 2cm resolution in some areas). As I can recall, all the other sampling tools don't make that random pre-sampling. I tried to overcome this by segmenting into smaller point clouds (cca 15Mpts) and it worked until around 15th point cloud when it started pre-sampling it again to around 1Mpts (again more than 2cm). From then on, in the same project, all other clouds get automatically pre-sampled to 1Mpts when spatial sampling is opened. The similar problem occured while using Multi-Ortho tool. I set a 1cm resolution ortho-projection from a 6mm cloud and I get swiss cheese Ortho-Photo (5-10cm). I want to know if it is possible to manipulate TRW into using bigger clouds for those heavy modules, or is it simply hardware problem?
Configuration:
Intel i7 6700
64 GB RAM
GTX1060 6GB
256GB SSD + 1TB HDD
Automatic Pre-sampling In TRW Modules
- Full Name: Martin Tokic
- Company Details: Geofocus doo
- Company Position Title: Laser Scanning Specialist
- Country: Croatia
- Mind
- Full Name: Mindaugas Juska
- Company Details: Elipsus
- Country: Lithuania
- Skype Name: mind.juska
Re: Automatic Pre-sampling In TRW Modules
Hi Martin,
I had this problem too. Yes, it is possible to manage larger clouds. Just go to Cloud based registration tool. On the bottom right corner there is a box where you can write max visible points. Also click on HD button. Then in the sampling tool you will see all points not only 20Mpts.
- Country: Croatia
Thank You Mind.
That worked. Halfway. It loaded 125Mpts. Further improvements depend purely on hardware: more Ram and CPU of course. It took ages to load mentioned cloud. Thanks again.
