Hi, I have problem with surface to model inspection. I have to check verticality of walls and columns in building and I have only my cloud point. I segmentated part of wall and I created a surface but I did't finde how to change the axis of surface to get correct results in inspection becouse sometimes I receve inspection from wrong side of wall.
or maybe is another method to check walls?
Surface Inspection in TRW
- Full Name: Ewa
- Company Details: Geo-Station
- Company Position Title: geodesy
- Country: Poland
- tchaper
- I have made 50-60 posts
- Full Name: Thomas Chaperon
- Company Details: Trimble
- Company Position Title: Senior software engineer
- Country: France
Re: Surface Inspection in TRW
Hi Ewa,
To view the orientation of a plane, select it, show its properties, and look at 'direction of normal' .
You can then edit the field if needed, replacing each coordinate by its opposite value.
Once the normal has the proper orientation, the inspection should show the values as you expect.
I hope this helps,
Thomas
I hope this helps,
Thomas
- Full Name: Ewa
- Country: Poland
