Need to change scale of imported .xyz file in RealWorks?
Discuss all Trimble Realworks related issues here.
Kelasa
Full Name: Christopher Rochette
Company Details: arup.com
Company Position Title: Assistant BIM Designer
Skype Name: Chris Rochette
Post by Kelasa »
I scanned a building, using a BLK 360 and a Matterport (to capture the inside of a large crawl space). In Realworks I have registered the BLK 360 9.e57) scans together. I imported the Matterport/Matterpak data as an .xyz (ASCII)file. The Matterport pointcloud has come in really small compared to the BLK scans.
Is there a way to change the scale of an .xyz file, so it could be resized to match the size of the pointclouds in my RealWorks project?
I appreciate your help. Thank you for your time.
Mike Annear
Full Name: Mike Annear
Company Details: Mike Annear
Has thanked: 58 times
Been thanked: 118 times
Re: Need to change scale of imported .xyz file in RealWorks?
Post by Mike Annear »
Is it a simple mm / metres problem ?
Can you change the Matterport export to metres ?
Mike.
Mike Annear
www.mikeannear.com
QLD, Australia.
TMillington
Full Name: Tony Millington
Company Details: ISIS Rutherford Appleton Laboratory
Company Position Title: Survey section leader
Country: uk
Post by TMillington »
I was just about to suggest the same thing, you can also set/change units when importing the ascii file to TRW.
Regards
Kelasa
Post by Kelasa »
Thank you both!
I got it. I was able to change the units from mm to feet, to solve the size issue.
I appreciate your guys' help!
Return to “Trimble Realworks”
