I'm trying to create textured low-poly meshes of scan data from Scene using Meshlab.
I have exported from Scene as .xyz, and the file appears to include colour data:
0.944600 -1.794700 6.050800 91.000000 76.000000 121.000000
0.910900 -1.789300 5.992900 105.000000 82.000000 116.000000
1.099600 -1.803400 6.042500 95.000000 80.000000 130.000000
1.078200 -1.820600 6.055800 84.000000 74.000000 105.000000
When importing the .xyz file into Meshlab all the points are grey. I have been following some guides to texturing a mesh from the original points, but without success, and I'm wondering whether Meshlab is reading the colour data – it certainly isn't showing it!
Help!
meshlab xyzrgb import
- shankskill
- Full Name: David Shanks
- Company Details: self-employed
- Company Position Title: self-employed
- Matt Young
- Honorary Member
- Full Name: Matt Young
- Has thanked: 45 times
- Been thanked: 40 times
Re: meshlab xyzrgb import
I'm no expert with Meshlab but Noticed in that example that the RGB Values have the same number of decimal places as the coordinates. I don't think the RGB values need the decimals and should be separated by a coma? just a thought.
I just found this post which might offer more help than my guessing...
http://www.laserscanningforum.com/forum ... 3&start=10
- shankskill
Indeed, maybe they're not even RGB values. Could they be normals? I wouldn't have thought they'd have zeroes after the decimals, but what do I know? Maybe I'll check I'm exporting correctly from Scene first.
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
In my experience the best solution is to use cloud compare as a bridge.
In cloud compare you can import E57, and now faro files too (I have to test it..).
If you have a text file cloud compare allows you to decide what is every column.
In cloud compare you can fuse, subsample, and do a lot of nice things.
Then you can export to meshlab using a format more compatible with Meshlab, like PLY.
- Full Name: Jacques Harvent
- Company Details: Noomeo
- Company Position Title: Research Engineer
- Country: France
Rename the extension .xyz to .txt. Then choose the x y z r g b option when importing the file.
Greetings,
jh
Greetings,
jh
- Country: Italy
Nice one!
Thanks,
Thanks,
- nfaino
- Full Name: Nic Faino
- Company Details: JENSEN HUGHES -previously CASE Forensics
- Company Position Title: Mechanical Engineer
- Skype Name: nfaino
Hi all,
This is exactly what I need, but I can't figure out how to get the Pre-Open Options to come up in Meshlab. Can someone help sort me out?
Thanks.
-Nic
Thanks.
-Nic
