Surface / Ground Model
3DReshaper, FROST, MeshLab, VRMesh, ZBrush & 3DCoat, CloudCompare, Etc
boxel0
I have made 70-80 posts
Full Name: Lewis Boxer
Company Details: Advanced 3D Laser Solutions Ltd
Post by boxel0 » Tue Mar 13, 2018 2:26 pm
Hi Guys,
Im need to surface / ground model created from point cloud data, whats the best software to use?
Im not looking for anything over detailed, i would like it to be quite light and I would like to be able to use it within AutoCAD and would be really nice if it transferred the RGB values across from the point cloud
I have tried using:
civil 3D
Cloud Compare
Lewis Boxer
Technical Director
e: lewis@lasersurveying.com
w: www.lasersurveying.com
gilles_3Dreshaper
Full Name: Gilles Monnier
Company Details: Technodigit
Re: Surface / Ground Model
Post by gilles_3Dreshaper » Tue Mar 13, 2018 4:52 pm
Hi Lewis,
do not hesitate to have a look at 3DReshaper.
We have a tool dedicated for this purpose.
See some examples here:
https://youtu.be/WuINn3q-uls
and here:
https://youtu.be/HgR0SdcbVzI
Gilles
3DReshaper Manager
http://www.3dreshaper.com
boxel0
Post by boxel0 » Tue Mar 13, 2018 5:05 pm
Can this data be imported into AutoCAD? What format?
Lewis Boxer
Technical Director
gilles_3Dreshaper
Post by gilles_3Dreshaper » Tue Mar 13, 2018 5:25 pm
Hi Lewis,
in order to get the result in AutoCAD, we also have a tool!
See a video here:
https://youtu.be/6UdsF3ETfMk
at 8'
Gilles
3DReshaper Manager
James Hall
Full Name: James E Hall
Company Details: Precision Measurements Inc
Post by James Hall » Tue Mar 13, 2018 5:32 pm
Point cloud data can be imported directly into C3D.
Go to your Prospector tab and right click on Point Clouds. This opens up the Create Point Cloud dialog box.
The available formats are .LAS, .PTS, .PTX and other assorted file types.
James,
chenlinhai
Full Name: chenlinhai
Company Details: GreenValley International
Company Position Title: Technical Support
Country: China
Post by chenlinhai » Wed Mar 14, 2018 9:45 am
Hi Lewis,
You can try LiDAR360, the 30-day trial version downlink is: http://www.greenvalleyintl.com/software ... -downloads
The Terrain module provides a suite of GIS tools for calculating calculating slope, roughness, aspect & contours from surface models. Additionally, it contains tools for repairing surface models, i.e., spikes, holes and extraneous values.
The youtube tutorial link of LiDAR360 Terrain module:
youtu.be/y9l_hSRj5mc
Linhai Chen
MarkL
Full Name: Mark Lupton
Company Details: SEA
Skype Name: markl9999@yahoo.com
Post by MarkL » Wed Mar 14, 2018 1:42 pm
If you use Recap and then open in Civ3D you can make a surface right there. You have He option of using a defined point spacing to reduce the number of triangles. With some editing I’ve found it works quite well. Then you have the advantage of having all the surfacing tools, profiles, sections etc.
Rikore
Full Name: Bruce Yager
Post by Rikore » Wed Mar 14, 2018 1:43 pm
Lewis,
I would give 3DReshaper a try. I've seen it do some amazing things with ground modeling.
Return to “Meshing Software”
